knocking sound coming from motor.
I started the car yesterday after it sitting for a month or so. it started up pretty good but i did notice the idle was high right at around 1,5k. So i reset the tps and it came down and as soon as i restarted it i heard a knocking sound coming from the passenger side. When rev the motor a bit where the throttle cable is it seems to get louder n faster. It kinda sounds like a woodpecker hitting a tree if that makes any sense. But i have never heard this sound before so im not too sure where to start. Im thinking i should start checking the pushrods but i want to ask before i start taking things apart.
Thanks
Jay
Thanks
Jay
A sound clip would help generously.
But to prematurely say what it might be, the main two things it sounds like are either rod knock or a valve contacting a piston. Both will increase with rpm.
A rod knock usually sounds deeper, with valve contact sounding more like a click or snapping your fingers.
Does the car have an aftermarket cam/springs/pushrods? A bent pushed or broken valvespring could be the culprit, even if stock. thats the easiest/cheapest out of the two to check and fix.
Just pull that valve cover and check the valvesprings first, then the pushrods.
It's more of a knock. When I get home I'll get a clip on my iPhone but I don't know if it will come up here. The car has heads n cam that were installed 2 years ago. It's pretty loud but only comes from the passenger header side.
well i started it when i got home from work & now the noise is gone. Like i said before i havent started that thing in almost close to 2 months. but ill keep an eye on it and see how it acts if i get to drive it this week.
