cam questions
cam questions
I have a 99 trans am with just a few bolt ons (cat back, slp air lid and cai, and short shifter), what supporting mods would I have to do before I did a mild cam? What about a more extreme cam (trex)? I'm planning on doind LT's and y pipe before I look into a cam, but I'm just curious as to what supporting mods I would need.
LS1TECH Sponsor
x2 pm Sam88gta1 look at my sig.
Also call Thunder Racing they will ask you the question that will best fit your needs.
I went with the TRak cam and love it.
http://www.thunderracing.com/
thanks for all the replies! Another question thoughg, I heard that with bigger cams Trex for example, you need to either get new heads, or I guess build your heads. Is this true? Or would this just be the best way to do it if money werent an option?
That is why Gene told me to go with the TRak cam over the TRex cam. He said I will get more out of the TRak cam and heads over the TRex cam with heads plus my other mods.
Like I said it best to call them they can help you a lot more then anyone on here......... they know there cams.
"TRak" - 231/234 .640/.590 112 LSA 2400-6800 RPM Power Band. Excellent mid-range & high RPM power. 3200 stall, 3.42 gear, computer tuning required. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Comp 921 Valve Springs are highly recommended.
I went with the Valve Springs: Patriot Extreme Valvespring
T-ReX v.2 - 242/248 - .608/.612 - 110 lsa 3500-6700 RPM Power Band. Violent mid-range & high RPM power. Requires computer tuning, 4000 converter on autos, 4.30's or greater depending on transmission. Works very well with nitrous and proper tuning. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Due to the extreme nature of this camshaft, piston to valve clearance must be verified when using modified cylinder heads.
Gives you some ideas of what mods you have for what cam you might want to get.
TREX here and would not have it any other way! Just add LTH (1 7/8), LS6 Intake, and some 243 heads (241's if you wanna go a bit cheaper) and your golden for the cam. And I would do true duals over a Y pipe but that just my 2 cents.
http://www.youtube.com/watch?v=YuagRNTZb2c
EG Mayhem II cam from Houston. 435rwhp/405rwtq to the wheels in my Z with stock heads and pulled hard. 2 of my coworkers and one friends have the same cam in their stock 241 head cars. One was 418rwhp through a stalled auto, one 426rwhp, and the other 436rwhp with stock ls1 heads/intake.
My car went 96mph in the 1/8 with a DA of 1500-2000ft in the hot houston summer air. Drove perfect with a great tune.
http://www.youtube.com/watch?v=0o_6XwPjdcI
http://www.youtube.com/watch?v=eJSOnB51Ilw
NP and they did not put 241's on the LS1 till 01-02 and in 98 they had the 806 casting heads. LS6 has the 243 casting number heads w/ sodium filled intake valves (lighter). LS2 has the 243 castings for the heads, but does NOT have the sodium filled intake valves.
