cam timing issue
Old 02-12-2011, 06:47 PM
boosted s-10's Avatar
Default cam timing issue
a friend of mine put a lsx block in his car and it will fire up then die right after. the car is throwing a po343 code and we changed the cam sensor and still no luck i havent checked voltage but will tommorow. my question is when running the lsx block do you run the half moon cam gear or the 4x cam gear?
Old 02-12-2011, 06:59 PM
Bad Chad's Avatar
What kind of car is this in?
Old 02-12-2011, 07:31 PM
camaro
Old 02-13-2011, 09:55 AM
nobody?
Old 02-13-2011, 08:41 PM
bigfatls6's Avatar
your gonna have to post up a little more info than just a lsx block and camaro. Is it a ls1 or 5.3 or what? What reluctor wheels does it have? Could be vats.
Old 02-13-2011, 08:58 PM
the crank has a 24 tooth wheel. i meant the actual lsx gm block.
Old 02-13-2011, 09:05 PM
mred's Avatar
stop what your doing and take it to reputable shop.
good luck
Old 02-14-2011, 10:09 AM
no shop needed. wiring harness was wrong so problem solved. lock it
up.
