Cammed 5.3
Old 03-04-2011, 10:14 PM
In-Zane Moderator
ZONES89RS's Avatar
Default Cammed 5.3
Sounds pretty good so far, this is a junk yard 5.3 carbed and patriot cam, hopefully i will drive it tomorrow to see how it does, still needs a water temp hooked up and get the trans fluid topped off, this 5.3 will be running all motor till i finish gathering turbo parts, this is unbtuned as well, i stabbed the #6 pill in the ignition controller, carb is untuned as well, here is the video:
Ehhaust will be 3 inch into a 3 inch y and a bullet dumped.
Old 03-04-2011, 10:28 PM
jay7199's Avatar
sounds sweet! your cars are pretty badass
Old 03-04-2011, 10:42 PM
In-Zane Moderator
ZONES89RS's Avatar
Thanks man, they are carbed so that means they are slow, LOL.
Old 03-04-2011, 11:18 PM
I-C5's Avatar
Nice build i wanted to do something similar on my old 82 chevy pick up.
Old 03-05-2011, 12:41 AM
In-Zane Moderator
ZONES89RS's Avatar
Well get to it, worth every bit of patience and money.
Old 03-05-2011, 10:10 AM
lawless_stunna's Avatar
Nice work zane.
Old 03-05-2011, 10:36 AM
retardedpenguin's Avatar
This the one that went in the firebird? Sounds good.
Old 03-05-2011, 12:15 PM
In-Zane Moderator
ZONES89RS's Avatar
Sure is, hope i can take it for a spin today.
Old 03-05-2011, 12:39 PM
v8
17,16,15,14,13,12,11 Drvr
v8's Avatar
sounds good
Old 03-05-2011, 07:21 PM
In-Zane Moderator
ZONES89RS's Avatar
Thanks, MSD is throwing a bad cam pos code, i let someone borrow mine and they gae me back their old one thinking it was not the sensor and too lazy to pull mine back off,
Old 03-08-2011, 07:06 PM
In-Zane Moderator
ZONES89RS's Avatar
Bitch is running pretty good now damn it:
Old 03-08-2011, 07:58 PM
imperial07's Avatar
thats pretty sweet. i've been bouncing around the idea of a BBC third gen the past few days and for me it seems like a win/win, just gotta sell my current car to get started.
Old 03-08-2011, 08:32 PM
In-Zane Moderator
ZONES89RS's Avatar
Big blocks are cool but I wanted something readily available from the scrap yard I can beat on to 7000 rpm in all my cars, lol.
Old 03-08-2011, 08:46 PM
Ws6kid.'s Avatar
nice! i like the idle sounds good.
Old 03-08-2011, 09:01 PM
TechCam97's Avatar
What cam did you use? I'm thinking of putting a 5.3 in a 74-77 Camaro (I know, most think they are ugly, but I love em...).
Old 03-09-2011, 06:12 AM
imperial07's Avatar
oh it will see 7k and probably more
Old 03-09-2011, 06:56 AM
In-Zane Moderator
ZONES89RS's Avatar
Will have a idle clip with the bullet muffler and Y pipe when i get the cash for the install, glad you like it.
This is Patriots grind, it is 225/229@.050, 582/589 lift on a 114 LSA. I like it, but it seems the 3000 converter might not be loose enough but i have fine tuning left to do.
Yea, pretty easily, but i am not sure where the power band will fall off, i still need to install the tach so i can even see where it is pulling to, i know it was SCREAMING playing on the back roads trying to see how it was running.
Old 03-09-2011, 07:19 AM
imperial07's Avatar
that cam is smaller than what i had in my gto so my guess is that power is falling off in the low 6k range, mine peaked at 6200 and it was TR's 230/236 cam.
Old 03-09-2011, 12:42 PM
In-Zane Moderator
ZONES89RS's Avatar
What year GTO? A 5.7 car will peak later than a 6.0 car with the same cam ad heads, cubic inches eats up duration, seen the same patriot cam run to 6800 in 5.7 liters so i am sure 7200 is where this one will pull to, also depending on your tune and supporting mods. My carb and victor Jr intake pretty much bitch slaps and induction you can get your hands on for less than 1000$ new, so top end is where the carbed setups really shine. I am using a 317 head set on my GEN IV 5.3, so i am still around 9.5 to 1 compression but flow the same as a LS6 heads, also another benefit for a smaller engine using heads that flow around 250 on less cubes. It is all in tot total combination, so if you had a 5.7 car, it would not surprise me you started nosing over at 6200 with LS1 heads, but it should still have pulled to 6500 minimum i think. But then again a GTO is a fat pig compared to allot of other car, my third gens especially, so i think you would notice the power band drop off easier than me.
Old 03-09-2011, 12:54 PM
imperial07's Avatar
it was a 5.7 car, it peaked at 6200 but it would rev past 7k, i just never liked doing that since i wasn't making power anywhere near there. i would shift it at 6700-6800 because the general rule is 500 rpm past peak to allow the motor to get back into the power band after shifting. if i do the BBC i will pay a little more attention about the rpm's and where it shifts for each gear because the car will be a street strip car with primary focus on strip, i may even pony up for a transbrake but i'm not sure if thats a good idea for a car that will see street duty.
Quick Reply: Cammed 5.3
