Anyone ever ran an F1-A on an AES boost motor?
Old 04-14-2011, 09:00 AM
vicouSS00's Avatar
Default Anyone ever ran an F1-A on an AES boost motor?
I've been hunting around trying to find a motor that will work good with my F1-A kit. I've gotten various quotes from different engine builders and came accross this last night..
https://ls1tech.com/forums/sponsor-s...lock-sale.html
Anyone ever used them? Seems like a good deal.
Kody
Old 04-14-2011, 09:25 AM
Formerly 4mulaJoe
LS1x2's Avatar
Seems like the cost savings is in the parts. I don't think I'd risk it.
Old 04-14-2011, 10:23 AM
Destroyer of Exotics
FlashWS6's Avatar
Whats the power goal?
Old 04-14-2011, 10:52 AM
nassty00's Avatar
just have em upgrade the rods. shouldnt be much more
Old 04-14-2011, 10:56 AM
vicouSS00's Avatar
In the ballpark of 800 rwhp
Old 04-14-2011, 11:08 AM
Moderator
BizZzatch350's Avatar
I'd take a GM factory crank over a cheap cast crank any day.
Old 04-14-2011, 11:36 AM
5w20's Avatar
As stated before by many respected engine builders here, that 370 will work and those brands of parts won't be an issue at the power level you are looking for.
Old 04-14-2011, 11:39 AM
AnnivSS's Avatar
Where are you seeing cast crankshaft? The post im looking at says....
Originally Posted by AES Racing
  • 6.0 Iron Engine block machined to blueprint specifications
  • line honed, bored, decked .010", tq plate honed, Crankshaft digitally balanced.
  • CP Pistons -13cc Reverse Dome dish design, 2618 Forging.
  • Chrom-moly steel piston pins, .180" wall
  • NPR Gas Nitrided Steel Top ring set, Napier 2nd ring, standard tension oil ring.
  • Eagle H beam rods 4340 Forged w/ ARP rod bolts
  • Factory GM crankshaft, balanced and polished
  • Clevite Bearings
  • Durabond cam bearings
Old 04-14-2011, 11:40 AM
5w20's Avatar
probably the 390 not the 370
Old 04-14-2011, 11:41 AM
AnnivSS's Avatar
Ah i didnt see the 390.
Old 04-14-2011, 11:43 AM
vicouSS00's Avatar
If I choose to go with the AES motor I'm defienetely going with the 370. Most likely ls3 heads and a custom blower cam from Bob @ Brutespeed.
Old 04-14-2011, 11:45 AM
5w20's Avatar
Originally Posted by vicouSS00
If I choose to go with the AES motor I'm defienetely going with the 370. Most like ls3 heads and a custom blower cam from Bob @ Brutespeed.
I think you should go with some 225+ TFS or AFR heads with the thicker deck.
AnnivSS's Avatar
Correct me if im wrong but isnt a f1-a a little overkill on a 370 for 800whp? ive seen d1's make that on 396's and 383's.
Old 04-14-2011, 11:47 AM
5w20's Avatar
No, just makes getting to his power level easier and spinning less boost which should mean less problems with belt slip.
Old 04-14-2011, 11:48 AM
AnnivSS's Avatar
Ah i see.
Old 04-14-2011, 03:25 PM
vicouSS00's Avatar
Yes 800 rwhp is just a ballpark #. Id like to make that on boost only and then eventually install a methanol kit and see what it will do.
Old 04-14-2011, 03:47 PM
Randy_S's Avatar
Why wouldn't you have HkE build you a new motor to handle the boost?
Old 04-14-2011, 04:14 PM
Moderator
I know, I was saying I would rather they use a GM crank, which they are, over some of these motors which rely on cheap cast cranks. The factory cranks are decent pieces.
Old 04-14-2011, 04:26 PM
vicouSS00's Avatar
I'm considering that.
I've already got a quote from Eric for a new block I was just really trying to weigh out my options and try and find something already built first. I was happy with my HKE 408 he built but Im just really not wanting to wait 6 weeks or longer to have a motor built again,(which in my case w/the 408 it took about 3 months), unless I absolutely have to. It just sucks seeing my car on jack stands w/ no motor and an F1A kit begging to go on lol Hard to explain..
Old 04-14-2011, 05:06 PM
Black2001z06's Avatar
Save yourself lots of trouble...send HKE your business, it will be well worth the wait.
Trust me on this...I know the EXPENSIVE way firsthand!
