Ls2 to lq9 swap.
Old 04-20-2011, 07:24 AM
rickykline's Avatar
Default Ls2 to lq9 swap.
What year model has The knock sensors on the side of the block? And the correct crank for my 6 speed?
Old 04-20-2011, 10:09 AM
In-Zane Moderator
ZONES89RS's Avatar
Probably a 2005 up LQ9 i believe.
Old 04-20-2011, 07:52 PM
rickykline's Avatar
i found a ly6 im going to look at tomorrow at lunch..
Old 04-20-2011, 08:34 PM
NemeSS's Avatar
Ly6 has thicker crank flange than lq motors
Only lq4 with thicker crank flange is 99/00 and came with iron heads
Old 04-20-2011, 09:05 PM
rickykline's Avatar
So a ly6 won't bolt to a 05 Gto t56?
Old 04-20-2011, 09:21 PM
In-Zane Moderator
ZONES89RS's Avatar
Will bolt to it but the flywheel will be out too far to even engage.
Old 04-20-2011, 09:29 PM
NemeSS's Avatar
I dont think will work
Does not work with fbod t56
At least its not just a direct bolt on
Old 04-20-2011, 10:51 PM
rickykline's Avatar
So what will it take ? Machine the flange down? Or add a spacer?
Old 04-20-2011, 10:52 PM
rickykline's Avatar
Crank will have to go to the machine shop anyways to get a 24x wheel installed
Old 04-21-2011, 02:09 AM
In-Zane Moderator
ZONES89RS's Avatar
A crank swap basically.
Old 04-21-2011, 06:25 AM
rickykline's Avatar
So who has verified this? Cuz There's quite a few people on here that say they are running a ly6 with the stock ls t56
Old 04-21-2011, 07:00 AM
rickykline's Avatar
I just want to verify the engine I'm going to to look at is a 2008 silverado engine. 6.0 iron block with vvt and l92 heads. My understanding was all the ls motors bolt to the ls t56 with the exception of the old lq motors.
Quick Reply: Ls2 to lq9 swap.
