hole in t/b?
Old 04-23-2011, 03:48 PM
s-10ls1's Avatar
Default hole in t/b?
well the hole in my 92mm t/b is 5/32. i was wondering what size hole you guys are running on your setup?
Old 04-23-2011, 04:30 PM
slowredz's Avatar
Why do you need a hole in it? Tuner problem?
Old 04-23-2011, 05:36 PM
s-10ls1's Avatar
No tuner problem, just wondering what other people are running
Old 04-23-2011, 06:11 PM
dlross's Avatar
i dont have any hole
Old 04-23-2011, 07:27 PM
rooster99ss's Avatar
People that can't tune drill holes in throttle body blades
Old 04-23-2011, 07:44 PM
s-10ls1's Avatar
all i asked what are other people are running on there setup. so if you dont have anything to say about the hole drilled in the t/b, then dont post on my thread. thanks
Old 04-23-2011, 08:15 PM
Ballerado's Avatar
I think what they are getting at is that they are running a 0/0" hole.
Old 04-23-2011, 08:34 PM
s-10ls1's Avatar
alot of them have holes. even my old stock ported and polished tb had a hole in it.
Old 04-23-2011, 10:25 PM
Ballerado's Avatar
stock, sure yeah it has a hole in it, but once you step up into the 92's such as yourself, from what ive seen, they do not have holes in the blades. Like the others are trying to tell you, its all in the tuning. If you dont believe the people who have chimed in here, then call the maker of the tb and get an answer from them, or a reputaple tuning shop im sure could give you a solid answer.
Old 04-24-2011, 10:28 AM
1c62nv's Avatar
I have a hole in my TB, its 102mm I also have a bad *** tuner
Old 04-24-2011, 10:51 AM
westtexasbuff's Avatar
I think most people drill holes in the tb for idle issues with cams.
This was my old TB, not sure what size hole is in the blade.
Old 04-24-2011, 11:25 AM
s-10ls1's Avatar
Thanks westtexasbuff, mine looks to be about the same.
