cam or head swap,central texas
Old 04-25-2011, 12:07 PM
fly pantera's Avatar
Default cam or head swap,central texas
alright guys im thinking of going a little faster in my auto z28 and with ahouse payment and bills money is tighter than before so im on a budget,if yall know someone that can install a cam swap or maybe a head swap then lmk,i do have some cash but cheaper is better for me.
parts have not been bought yet,just throwing it out there.
Old 04-25-2011, 12:12 PM
SSHAWK's Avatar
I would get the parts you want first..... then see if someone on here might do it on the side in your area.
Most of your cost will be in the parts.
But just remeber you will also need to get your car tuned.
Old 04-25-2011, 12:42 PM
i was quoted 700 for a cam swap,so just seeing if someone with a good rep can get that # lower
Old 04-25-2011, 12:47 PM
SSHAWK's Avatar
For part and labor? If so thats a deal..
If this is for labor only your getting robbed lol
I paid $730 for cam, springs, pushrods. retainers. thats no labor.
Thunder Racing LS1 Cam Swap Package w/ Dual Valve Springs Includes:
- Your Choice of Thunder Racing Camshaft
- Dual Patriot Gold Valvesprings and Ti Retainers
- Thunder Racing Pushrods (7.400)
- Valve Stem Seals
- Additional spring options available below
CAMPK-PG-EX Thunder Racing LS1 Cam Swap Package w/ Double Springs $719.99 $719.99
Options
Sprocket Pattern: Standard (3-bolt) LS1, -6, -2 Series
Valve Springs: Patriot Extreme Valvespring $20.00 $20.00
99-TRAK-CAM Cam: 99-TRAK-CAM
Subtotal
$739.99
Old 04-25-2011, 01:25 PM
- Valve Stem Seals
Options
Subtotal
$739.99
700 was for labor only,thats why i threw it out there i havnt been in a shop in a longtime and i thought that was high.
i can get pac 1518 springs good to .650 for 150
cam looking for low 230s under 620lift-------360
speed in pushrods----------------------------90
subtotal--------------------------------------600
Old 04-25-2011, 01:32 PM
SSHAWK's Avatar
You should look to spend about half that in labor.
Some places will do it lower.
Old 04-25-2011, 02:30 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Generally I charge 300 for a cam swap and 700 for heads and cam. That price depends on how much the owner helps me and how busy I am at the time. Id do it for you but Im in the process of moving and got a ton of other stuff going on. If you need it done closer to the end of the year I could help you out otherwise Im sure you could find someone around here to do it.
