2012 F250 6.7 FX4 diesel, yes or no
Looking to trade in my 2010 Tundra 5.7 4WD crew max for a 3/4 ton cc diesel. Looking very strongly at a new 2012 lariat and would like honest opinions about the new Ford engine. As we all know the 6.4's were total junk for the most part and the 6.0's were not that much better. I am a Gm fan for cars and suv's but thier trucks don't do much for me appearance wise. Looking to do something within the next week or so so post away. As always your opinions are appreciated.
The owner of the company I work for has a 2011 F250 XLT with the 6.7, just bought it at the beginning of the year. He puts a lot of miles on his trucks driving across the country to meet with distributors, customers and to put our products on display at tradeshows. I think he already has around 20-25K on it with no problems to date. I would still be wary of Fords new generation of diesels, none have proven as reliable as the old 7.3. Although I have not heard much bad about the 6.7L yet. The 6.2L gas engine is no slouch either at 385HP and 405TQ.
the 6.4's are total junk eh? tell me more about all your horror stories and experience with them.
All 2008-2010 f250/f350 diesels were a 6.4 sir, not a specail edition at all, standard issue. Check your info before posting a sarcastic comment and making an *** out of yourself like you just did.
I never owned one or any 3/4 ton diesel, Just heard numerous nightmare stories from actual owners of the 08-2010's. I also know of a close source (on here) who works on them on a daily basis and heard some pretty scary stuff with the 6.4's.
Now that I actually stop and think about it, I do remember hearing of the 6.4's
Thanks,what are you averaging mpg wise with the trailer and how heavy trailer are you towing and is it open or enclosed? I will entertain the Gmc duramax but the Ford gives me more options per buck vs Gm unlessi opt for the Denali which is out of my budget.
No sarcastic comment I really didn't know they made 6.4, never messed with diesels. Now that I reread my post it did come off as sounding sarcastic. My apologies. I'm sure you will be happy with whatever your choice may be.
LS1Tech Co-Founder
If I were shopping to buy a new 2011-2012 diesel truck, and all of the financial deals were the same for each brand, I'd go GM Duramax 2011+
2011 and newer has an all new chassis/steering under it, they drive much nicer than the previous 2008 Duramax I had. I like the Dodge interior/exterior, but the current Cummins is a little thirsty like the Ford is. If I buy a diesel, it needs good mpg primarily.
you always hear the worst, but out of the millions that are made they haven't had that extreme of an issue.
the shitty part is dealing with regen, epa emissions/clean air act deal.
I've owned my 2008 brand new and have had zero issues. It has been an amazing truck and hell even makes great power with tune/dpf delete/intake. Surprises most people :o
man that sucks, but i would never take the word from somebody that drives the **** if an ill maintained work truck.
I can't say much for gas mileage as all clean air act diesels aren't getting good mileage period w/o the tune.
although it is the lie meter i did calculate it out and typically get 18/25 when i was on stock tires.
around 12/15 without the tune on 35" tires.
mine is a Job III
above view, you can see where the first turbo feeds directly into the second.
4" from the factory, loaded with the the dpf system. VERY heavy and restrictive.
when i had the mods installed before my replacement ranch hand, leveling kit + add a leaf and 35x12.50's
took this last weekend, my overall mileage from round trip to dallas.
*forgot to mention, was bought new March 2009 for 33,130 TTL out the door (i'm an A plan buyer with ford) ***
have not one single issue with this truck.
beyond needing the cab off to do some of the major mechanical work if something does happen to fail some of the major issues i've seen were due to negligence of maintenance.
fuel filters are a huge deal on this truck, instead of using the high pressure oil pump which controlled injectors and other various things on the previos 6.0 and 7.3, they run a flywheel driven high pressure fuel pump on the 6.4 and now 6.7. It doesn't take much to destroy this fuel system which ford is very particular on which fuel filters used, and how often you're supposed to change them. The truck fuel rail pressure is ~6,000psi and can get up too 29,000psi under full throttle.
pretty amazing machines and seems they are getting great longevity, especially out of tuned trucks.
Thanks for the input guys, kinda what I wanted to hear. Ok truth of the matter my Tundra pulls my light trailer just fine. Yes it sucks on the gas while doing so but it does the job non the less. As for the 6.4's I'm only going by what i heard from mechanics,other Ford owners and talk in general even the sales people advised against it (at Ford) obviously to persuade me into a new one. I guess I'm just wanting a nice diesel 4WD to play around with. My Tundra averages 14.5 empty city/highway which is not too awful bad and it's a hell of a truck. i just like the look of the new Ford sd's.Secondly I know the duramax is more proven and less thirsty but outside of the Sierra Denali they don't do much for me and the denali is too pricey for me. I'm leaning on the F250 but might look at a cpo Denali idk. Will keep you all updated.
