Need to get springs and z06 cam installed asap
Old 03-26-2012, 12:02 PM
GothamCity's Avatar
Default Need to get springs and z06 cam installed asap
I buddy of mine is putting my lM7 in my 72 cutlass and we need a recommendation of shop on the Southeast side who could do the job. Or even a shade tree mechanic. He called a shop and they told him they needed to remove heads to do the job...from the research I have seen on the swap removingthe heads are not needed. Also the engine is on a stand in my buddys garage...Need help asap...
Old 03-26-2012, 12:36 PM
02silverstang's Avatar
This friend of your doesnt happen to be named Joe River ? if not I can install the parts for him
Old 03-26-2012, 01:00 PM
chupr0kabra's Avatar
Protip: Saying "southeast side" is only helpful if you tell us which city you're in.
-Mike
Old 03-26-2012, 01:12 PM
GothamCity's Avatar
Southward of Houston
Old 03-26-2012, 01:16 PM
GothamCity's Avatar
@silverstang..playboy I gave you first shot at my Lsx swap..and you increased your original quote by 600.00 so its not personal just business...
Old 03-26-2012, 01:31 PM
8 Sec Tuner
Mike TexaSS's Avatar
Cam swap is easy. Pm me
Old 03-26-2012, 02:06 PM
GothamCity's Avatar
Thanks alot to all those who've replied and hit me up!! This site is awesome
Old 03-26-2012, 02:24 PM
Mike96z's Avatar
Can easily be done without removing the heads, need a fitting to place into the spark plug hole to fill the cylinder with air and then pulling the cam out isn't very hard either.
There are other methods of doing this though.
Old 03-26-2012, 07:53 PM
04Vguy's Avatar
so you need a cam installed or a motor installed or both. cam swap is easy breezy
Old 03-28-2012, 07:36 AM
Humm I was going to do the cam swap , assemsble the whole engine , attach the engine to the transmission , remove you old your old engine , reinstall you new engine get everything hooked up , take the car to a muffler shop to get all the exhaust connected correctly , get all the fluid and any odds and ends for
$1600
and I told you it would have been less depending on the minor stuff needed and what the muffler shop would charge.
So any one on here who knows is $1600 for a complete lsx swap in a car that is not an ls based too much. take it to a shop then they would charge you twice as much.
and by the way this has been going on for 6 mo that you have been trying to get everything together.
Old 03-28-2012, 11:17 AM
GothamCity's Avatar
$1600
Ceaser no worries bro....from what I have seen you do good work..just you originally told me 1000.00 since I already had my harness and pcm flashed. Also I will be working with my buddy to get some experience as well...Wish you the best bro..
Old 03-28-2012, 12:47 PM
Ok sounds good peace !!
Old 03-29-2012, 04:24 PM
GothamCity's Avatar
Shout out to my mans 5w20..took care of my cam install!! This site rocks...now on to the truck accessories and ls1 intake....searches say change balancer to smaller diameter or idler relocation bracket or spacers...which cheapest and I have the f-body water pump on my 5.3
