Broken #6 intake valve spring/H/C question
Old 04-01-2012, 11:39 PM
jarheadtex's Avatar
Default Broken #6 intake valve spring/H/C question
So, I have been trying to figure out this misfire my car has been having that started Friday while cruising. I pulled the valve covers and the #6 intake spring is broken. I drove a good 40 miles with it like this. I rotated it by hand and the valve goes up and down like it should. My question is 1...: Where can I get new springs tomorrow ..its my DD and need to get it back on the road.
Or.... Would it be worth it to put new heads on it with the possibility of a damaged piston?
Im in Ft Worth, the car has Comp beehive springs with like 20k on them.
Old 04-02-2012, 11:15 AM
I-C5's Avatar
u could put a stock one in until you find a replacement...just dont beat on it. Was the retainer clip still attached to the valve? if not id pull the head. well id pull the head anyway just to check the valve and the piston.
Old 04-02-2012, 12:08 PM
Mike96z's Avatar
You could replace that spring but if you want to be sure it's not all torn up you need to pull the head.
Old 04-02-2012, 12:52 PM
red90cobra's Avatar
do a compression test on that cylinder then compare it to he ones close to it after you replace the spring. If the compression is down you got a bent valve.
Old 04-02-2012, 01:24 PM
jarheadtex's Avatar
The spring was still attached to the valve. I'm replacing the springs tomorrow so ill see how it runs.
Old 04-02-2012, 01:47 PM
5w20's Avatar
this warrants a leak down test
Old 04-02-2012, 03:13 PM
jarheadtex's Avatar
OK..ill give it a try
Old 04-02-2012, 03:47 PM
00pooterSS's Avatar
Put a spring on it and see. I have replaced many over the years without issue.
If you can move the valve up and down and spin it it is probably fine.
A leakdown or compression check would be good, but I definitely wouldn't pull the head just to look. All that you are gonna see is maybe a bent valve and a mark on the piston. If the spring fixes it then the valve is fine and the piston wont have enough damage to cause any issues. So if the spring makes it run okay pulling the head would be a complete waste of time.
Old 04-02-2012, 04:16 PM
01 WS6 6.0's Avatar
You got lucky same thing happend to me but the calve broke at the umbrella then flipped and wedged into the piston didnt put a single mile on the set up
Old 04-02-2012, 09:24 PM
jarheadtex's Avatar
Yeah, I get the springs tomorrow Im going to install them and see what happens. I think everything is fine.
Old 04-02-2012, 09:25 PM
jarheadtex's Avatar
DAYUMM that sucks ...did it make a wicked noise?
Old 04-03-2012, 12:16 AM
01 WS6 6.0's Avatar
I heard something drop turned the car off and removed the head and found the valve in the piston
Old 04-03-2012, 02:23 AM
chrysler kid's Avatar
I got a bad batch of comp springs back in the day, I got lucky and one broke at idle and didn't do any damage. Go with patriot springs
Old 04-03-2012, 02:32 AM
lilaaron233333's Avatar
I have a full set of springs for sale if ur interested
Quick Reply: Broken #6 intake valve spring/H/C question
