need help with ls1 f body engine harness grounds
Old 04-30-2012, 10:43 PM
one fast zo6's Avatar
Default need help with ls1 f body engine harness grounds
hi, i need help with ls1 f body engine harness grounds. where do all the grounds go? i got he three on the back of the drivers head, but what about the driver side frame rail and all the braided straps?
thanks
Old 04-30-2012, 10:59 PM
5w20's Avatar
Originally Posted by one fast zo6
hi, i need help with ls1 f body engine harness grounds. where do all the grounds go? i got he three on the back of the drivers head, but what about the driver side frame rail and all the breaded straps?
thanks
Did you fry the breaded straps?
Old 05-01-2012, 07:15 AM
jiveass's Avatar
oh man i just dealt with this problem when i did my swap..still dont know if i got em all...had to ground the computer with a new wire cause apparently i missed one somewhere...car wouldnt start without it. i believe there are the ones on the back of the head, and the driver side rail, and the main one from the battery...not sure if others exist.
Old 05-01-2012, 08:32 AM
Dave_the_SS's Avatar
-Trunk Hatch Release Bracket (2)
-Below Left Front Seat (Firebird Only)
-Center Rear of Roof (Camaro, Coupe only)
-Near left of Done Light (Camaro, Vert)
-Right Kick Panel
-Left Kick panel
-I/P Harness, Near Instrument Cluster
-Top Left of Radiator Support
-Top Right of Radiator Support
-Left Rear of Engine (3)
-Right Front of Engine
-L/F Shock Tower
-R/F Shock Tower
-L/F Frame Rail
-Right Side of Engine Block (BATT - )
-Lower Left Side of Engine
-Below Center console
Old 05-01-2012, 08:39 AM
Pages 25-28
http://cs.chevroletclub.net/graphics...g.diagrams.pdf
Old 05-01-2012, 12:22 PM
ok thanks but where do the two breaded straps go? the one's one the drivers side front engine bay down by the Alternator? one lead is from the frame rail and one lead is from the engine harness. where do they get grounded? the engine, alternator or what? ps this car is running
Old 05-01-2012, 12:30 PM
5w20's Avatar
You must like to fry everything. Breaded straps ALV.
Old 05-01-2012, 12:49 PM
yes you are smart, but do you know where the braided grounds go LOL
Old 05-01-2012, 01:22 PM
GreatWhiteZ28's Avatar
one from the drivers side frame rail goes to the front of the block somewhere or head if I'm not mistaken.....I'd go look outside but my motor is out of the car..lol
Old 05-01-2012, 07:51 PM
Old 05-01-2012, 09:19 PM
5w20's Avatar
I think those two on the driver side frame rail go to the block. It's been awhile so I might be wrong.
Old 05-01-2012, 09:28 PM
TT-TECH Veteran
Inspector12's Avatar
The one on the driver side goes from the block, just behind the altenator (10mm) on the same bolt that holds the front O2 plug. And goes to the frame rail also a (10mm) and has the groung from the front headlight harness on the same bolt. I think this is the one you are refering to. I know where they all go lol! As a matter of fact I can put an F-body together with all the bolts in a box, I don't need a template. GL!
Quick Reply: need help with ls1 f body engine harness grounds
