Ac idler pulley torx t50??
Just replaced the tensioner pulley for squealing now the damn Ac idler pulley is squealing its *** off. Im having trouble getting the t50 bolt out...any tips tricks to remove this?
Tips to get it out.. Looks like its in there pretty good, not trying to strip it. I dont understand why GM would put a freakn torx bolt there...pretty stupid
Im actually heading to Sears now to pick up a mini torch lol. Im off tomorrow so ima give it a shot.
1 Post
Ok put the torx on a ratchet and get it set to where when you can get an open ended wrench on it. I used like a 17mm, just use something long enough to get some torque on it. This should give you enough leverage to break it loose.
Also do not buy a new pulley, go get some bearing grease and pop the seal off and pack the bearing. It took me about 20 minutes to remove all of the pulleys and repack them.
FYI this did not totally eliminate the squeaking. IT did help a bit and gave me peace of mind. BUT what you definitely want to do is buy the Goodyear Gatorback belts. That should have been the first thing i did. It totally eliminated my chirping.
Also if you search a guy did a write up repacking the bearings. Search for chirping.
that's why you have to take it slow... a t50 is a good size bit, i would think a name brand ( snap-on, matco, mac) torx socket would be able to get it out just fine... they also sell impact grade torx sockets but the name brand ones are pricey
I think the bits an AutoZone brand not sure but I'll definitely take ur advice and try a bigger name bit
