Anyone know T-56's fairly well?
I posted this in the manual sections,
https://ls1tech.com/forums/manual-tr...p-solving.html
but am not getting any help so far. The other day to work after downshifting, my transmission has stayed in 1st. Clutch still works an you can "shift" the gears, but even in any of the other gear slots, it still remains in 1st gear. There is no neutral or reverse. Just 1st gear lol.
Now, I do know my clutch is on its last leg and my tranny does have its issues. But I'm tryig to make it last till January when I'll be able to rebuild to stage 2 and do clutch/master cylinder swap. I'm certain it's something fairly affordable and simple but I do think I may have to drop the tranny. Any and all help appreciated!
Duke
Duke
so you can put your shifter in different gears while in motion and you will always be in first gear? from what i am interpreting based on what you are describing, it doesnt sound like there is anything wrong with your clutch, it sounds like you have a transmission problem. something in the shifter or shift rail, shift fork, slider, etc.
From your description sounds like its stuck in first, you can move the shifter but it's still technically in first. Probably have a broken fork so you can move the shifter but you can't actually shift gears. Will need repair im sure.
I would start with pulling the shifter first and seeing if everything is ok there. If that checks out, time to pull the transmission. The clutch has no effect on being able to select a gear.
Check, and mate. Did last night. Shifter checked out ok.
If the shifter ball wasn't in there correctly the shifter would feel very loose and not right, should be noticeable. Now since that isn't your problem your going to need to pull the transmission and take it somewhere or have it pulled. Most people will tell you that you won't find the internal issue without pulling it apart. Then once they pull it apart they will tell you how many other worn parts there are that need to be replaced because they will soon wear out. That's just the way it goes unless you find some other reason why this thing wont shift outside of the transmission.
I've rebuilt a T-56 before and there always something that needs to be replaced when you pop it open.
Exact same thing happened to me but it was 6th gear instead of 1st so I couldn't even drive it home. I don't remember for sure but I'm pretty sure it tore some **** up. I had 6 speed inc rebuild it. Good luck tho
