PLEASE HELP with P0342 code tach drops to zero
So I recently pulled my old LQ4 and put in a new one now Im throwing P0342 which is a cam positioning sensor low voltage code. The things that have changed, cam, I went from 226/234 .598 .612 to 234/242 .605 .615, ls6 crank, and longer connecting rods(6.3). It starts up fine, runs fine, doesn't seem to loose power at all but when i reach 3200rpm the tach drops to zero then throws the code. I can rev it fast from idle and it will work fine, when I rev it slow it drops to zero every time and after a few seconds the tach starts working again. Here is what ive gone through so far. Replaced cam sensor, crank sensor, battery, pcm, checked the wiring harness from the pcm to the cam sensor then made a new harness to replace it and still nothing. I also checked the cam bolts and grounds and everything is fine there. I haven't tried a crank relearn yet, but that's next on the list. Could this be something that can be corrected in the tune? Would the bigger cam, ls6 crank or longer rods effect this? Any help would be greatly appreciated this is starting to drive me crazy!
LS1 Tech Administrator
Crank relearn was the first thing that came to mind.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
