question about lq9 build
Old 04-21-2013, 09:59 PM
DarknessHunter's Avatar
Default question about lq9 build
ok so I replaced all main and rod bearings with new ones tqed everything down to spec and properly lubed it all, so should crank be hard to spin since new bearings havnt worn in or did i fudge up somewhere
also using 241 heads so should i use the lq9 head gasket or 241 matched head gasket
Old 04-21-2013, 11:52 PM
ex-SS-ve's Avatar
Did you mic or at minimum plasti gauge any clearances? Never once should you take for granted that all those bearings and machine work are spot on. Even one or 2 bearings that are off .005-.01 will cause it to hang up like that. That motor should spin freely with even a 1/4 inch wrench on the crank with no plugs in it.
Old 04-21-2013, 11:53 PM
ex-SS-ve's Avatar
As for head gaskets use what the shortblock calls for
Old 04-22-2013, 08:35 AM
cool and thanks for the info i loosened cap one and spins no prob ill re check all the clearances. i used plasti to check before assembly and checked for rotation after tqing each cap and rod and it spun freely then i installed cam, timing chain oil pump and it still spun fine. i added some oil to the pump to see if it was working spun it and all good, came back 30 min later and i wouldnt spin any more.
Old 04-22-2013, 09:00 AM
KCS
Moderator
KCS's Avatar
It doesn't really make sense why it wouldn't spin after you came back. Make sure the caps went in facing the right direction, set the thrust, and that the timing chain isn't rubbing the oil pump.
Old 04-24-2013, 07:50 PM
checked all got it spinning again all back together now just need to get head gaskets
thanks
Quick Reply: question about lq9 build
