Bought a Nelson Performance tuned car...mistake
Old 07-11-2014, 11:59 AM
codyvette's Avatar
Default Bought a Nelson Performance tuned car...mistake
This will cost me time and or money, no matter what. BS in my opinion. I guess I will have to change out the PCM and start over. I guess they have magic tunes.
Old 07-11-2014, 12:05 PM
FireHawk178's Avatar
They locked it or it's just jacked up?
Old 07-11-2014, 12:44 PM
codyvette's Avatar
Locked it. Now I have to replace the PCM or take the time/money to send them the PCM. I will just change the PCM. This is just a rant and to worn those buying a San Antonio area car. We all know the best in the business don't lock there PCM's. There are ten reasons why not for every lame reason why.
Old 07-11-2014, 03:22 PM
Noah Burns's Avatar
the ones that lock their tunes are the ones that aren't confident in their abilities...
Old 07-11-2014, 06:27 PM
62nalide's Avatar
Nelson Performance in SA right? I've been telling folks for years my opinions about him and glad most of them saw the light. LOL telling me a 6L80E won't handle 500rwhp
Old 07-12-2014, 08:07 AM
1bad03snake's Avatar
I have a friend with the same issue. We are going to swap ecu's and start over
Old 07-12-2014, 08:42 AM
TXZ28LS1's Avatar
Could you tell a shop like nelson who locks their tunes to not lock it when it gets tuned?
Old 07-12-2014, 10:11 AM
codyvette's Avatar
They will not tune a car and let it leave unlocked. No exceptions. It says it in there diclaimer. For some people this may be o.k. I don't want to be a slave to any shop/tuner. If I want to try a different set of injectors, plugs, or anything for that matter I want to be able to do so for myself. I am not the original customer to Nelson so I am not asking for anything from them. This was just a rant and a warning to others that may not know. You can get your vehicle tuned by many different shops on there dyno and then head out to the track for some more adjustments. If they are worried about someone jacking with the tune and saying they did a shotty job all they have to do is compare the current tune file with the one they last loaded and they will know instantly that the customer will have to pay for a retune. This would be like buying a crate motor already dyno tuned and it showinh up with the distributor welded in place and the bowls glued shut on the carb. It is just lame.
Old 07-12-2014, 02:06 PM
stoverz28's Avatar
I had another SA shop try and charge me $100 for just a simple unlock on the computer I had them tune. Told them this was just like a mechanic putting a pad lock on your hood then charging you to get it off not to mention used pcms go for $125 all day. The whole thing is just pure bs.
Old 07-12-2014, 02:50 PM
62nalide's Avatar
Yeah that's why sometimes its best to remote tune vs a 1 time dyno tune and getting it locked
Old 07-12-2014, 03:47 PM
codyvette's Avatar
Just don't use these types of shops. I have HP tuners and will correct the problem. I would worry about the tune even if the car ran well.
Old 07-13-2014, 02:07 PM
chevrolade's Avatar
Just have em unlock it for free? That's what I did
Goodluck
Old 07-13-2014, 05:24 PM
94form2000z's Avatar
Another tuner should be able to upload a similar year car with similar mods as a base point and then be able to continue from there to do a tune on yours. Years ago I had one that was locked by a guy and had it retuned by another tuner who did just that. Paid him the same price as a regular tune to do so.
Most tuners don't want others looking at their work and duplicating it. That is why they lock it. Not saying it's right at all but if you know they are going to do it before hand then you have the choice in whether to use them.
Good luck.
Old 07-13-2014, 06:34 PM
2KSS's Avatar
WOW !! Thanks for the heads up ! I was considering taking my Vette to them.
Old 07-13-2014, 11:03 PM
camaroboricua's Avatar
I know 2 guys that had their cars tuned by them and ended up buying new PCM's because they were locked. I think even if its to protect your tune, what about the customer? you are taking away his ability to do as he pleases with his car unless he pays to get it fixed. And last I heard(from my friend whose tune was locked) their dyno has been broken for a while too so its all street tunes.
Old 07-13-2014, 11:48 PM
chevrolade's Avatar
Lol smh
Old 07-14-2014, 08:16 AM
So those buying a new PCM, why not take it back to them if they are within reasonable distance and pay to get the stock tune flashed back on? IS that not cheaper than a new PCM? If it was tuned there they should have the original file saved for the car. Then go get tuned wherever you would like. Seems like a lot less work then replacing it.
Old 07-14-2014, 10:00 PM
codyvette's Avatar
They are not in reasonable distance from me. I made a long haul to buy the car. We are sending the heads off for port work and adding a new fuel system including injectors. The point is , it is shitty to lock a PCM. Anyone who has been tuning for any time knows that just copying a tune from one vehicle to another will lead to disaster. The way you correct your VE tables and your MAF tables may vary but that can't be seem by looking at the tune file. I have vehicles tuned because of the dyno readings. After that, what I do with my vehicle should be up to me. A good tuner knows that even if his tunes are read by others that they will return to him time and again when they need help because they aren't quite sure how he got there. As far as WOT tuning goes, opinions can vary as far as perfect AF ratio and timing but the truth is there no perfect and every situation can change. One shouldn't have to pay nor take the time for an unlock because it is shitty to begin with.
Quick Reply: Bought a Nelson Performance tuned car...mistake
