Duramax Injectors
Duramax Injectors
I think I have some injectors that are failing on my 2007 LBZ Duramax. Does anyone know of anyone that can test these bad boys, in the Houston area, that won't charge an arm and a leg? I am not throwing a code, but I am having some white smoke and a bit of a rougher than normal idle.
Thanks.
Thanks.
how many miles are on it? over 100k id assume.
go beat the **** out of it and see how much worse it smokes
if its smoking its injectors 99/100 times. injector pumps arent as common on the new ones.
Apparently my programmer, The Autocal efi live, can read balance rates. I just have to download the software and push it to the programmer.
I am over in the Heights area.
