NEED HELP Tuning/or repin.
Old 11-14-2015, 10:49 PM
ski7541's Avatar
Location: Sweeny College Station, Somewhere in Afghanistan
Smile NEED HELP Tuning/or repin.
Okay folks, need some to help me figure out the issues with my 1998 Z28 Camaro. I had 02 sensor light on, I changed bought up stream sensors because the rear has simulators plugged in. I replaced the sensors drove it to work , pop a light on at idle . I clear the code with handheld and drove it home no light came on until I went to idle at lights. So can someone tell me what the problems would be...
Car has long tubes, cam, bbk intake, heads,cai.
Or is there someone that will repin the car for me. So I can run a newer computer and tune it right.
Thanks for your input.
Old 11-15-2015, 12:06 AM
codyvette's Avatar
If you are having bank 1 or 2 sensor 1 (fronts) codes you need to figure out why through diagnosing it in person. There is a laundry list of possible problems from a vacuum leak to low fuel pressure. If it is a code for the rear O2's just turn them to no error reported.
Old 11-15-2015, 01:18 AM
ski7541's Avatar
Now I'm getting bank 1 and bank 2 low voltage signal.... really don't know the issue there.
Also running rich at idle...
Old 11-15-2015, 05:14 PM
codyvette's Avatar
Sensor one or two?
Old 11-15-2015, 06:04 PM
GMCHammer's Avatar
Have you checked the ENG SEN fuse under the hood?
Old 11-15-2015, 09:48 PM
ski7541's Avatar
What fuse? Where?
Old 11-19-2015, 08:21 PM
ski7541's Avatar
Alcon,
Correct me if I'm wrong. I was told there is a PCM for 1998 Camaro that has a rewired PCM for the fuel gauge fix for sale, so you wouldn't need to change out the fuel sending unit. But you would loose TCS, and VATS, and the oil/water Idiot lights....(that's fine if I can have a better PCM tuning).
Old 11-20-2015, 07:01 AM
codyvette's Avatar
Vats, etc. Can be added back to the tune file.
Old 11-20-2015, 09:45 AM
ski7541's Avatar
Originally Posted by ski7541
Alcon,
So I can ru n a 411 or different pcm in a 98 model carmaro .
Old 11-25-2015, 06:54 PM
ski7541's Avatar
Can I have the harness repined and run a newer computer, without changing the fuel gauge and dash cluster?
Old 11-25-2015, 08:52 PM
codyvette's Avatar
The cluster only takes a few minutes to change. I wouldn't let that stop me. 99+ computers are physically the same. IE, you can do a write entire and install a 2001-2002 OS in a 99' PCM and it will be the same as a 411.
Old 11-26-2015, 09:25 PM
ski7541's Avatar
Okay, so why do I need to change the cluster? and if I do , would I need to change anything else?
Thanks in Advance.
Old 11-26-2015, 10:02 PM
codyvette's Avatar
There are probably others that can answer that question better than me. I have never done the cluster swap.
Old 11-27-2015, 12:55 PM
LSX Power Tuning's Avatar
You do not have to change the cluster if you do the re-pin to run a 99+ pcm. Your fuel gauge will not work without the fuel segment being swapped in the 99+pcm.
Old 11-28-2015, 12:41 AM
ski7541's Avatar
Thanks for the info on the cluster. But how do I get the fuel segment swapped in the new PCM. Is this something a tuner can do?
Old 11-28-2015, 07:02 AM
codyvette's Avatar
Yes. LSX Powerrtuning can do it for you. He is always on here helping out for nothing so it sure won't hurt to throw a little business his way.
Old 11-29-2015, 06:28 PM
ski7541's Avatar
Thanks for the information, I will be visiting him after I get my car back together, heads , cam, basically a top half new rebuild.
Old 12-11-2015, 10:23 PM
ski7541's Avatar
Okay so , how do I get the ses light to go off. I haven't done any swaps or repins yet....I have changed the 02's and there are simulators in the down stream ( and the lights are flashing on the sims), will all this be corrected with a newer ECM installed? Just looking for some advice.
Ski
Old 12-12-2015, 09:11 AM
Are you sure the sims are working? I havent even seen any sims in almost 10 years.
Old 12-12-2015, 08:05 PM
ski7541's Avatar
I was told if the light is flashing then they are working....
Quick Reply: NEED HELP Tuning/or repin.
