Need a nitrous wet kit!
Anyone have a hook up on nitrous kits? brand doesn't really matter (unless it should?) just has to be a wet kit because I'm sticking with the factory pump and injectors
Go with whatever your budget allows. If you go with Nitrous Outlet you can buy the regular nitrous kit and then later buy the adapter kit with the plate and install it with the kit you already have. I think the plate kit is like $300 more than the regular kit.
If you have the cash just go with the plate kit from get go and buy a box to pull timing.
