what is the biggest tire i can fit ?
Old 02-11-2005, 09:00 AM
eric01ss's Avatar
Default what is the biggest tire i can fit ?
anyone know what is the widest tire that can fit under a 88 chevy 2wd p/u
Old 02-11-2005, 11:01 AM
V6 Bird's Avatar
Tubbed or not? lowered? Frame C-notched?
Id say like a 15X10 with something like 12" wide tires.
Mike
Old 02-11-2005, 11:33 AM
foxspy's Avatar
I'm trying to figure that out as well. I'm trying to get a bigger tire under my 1990 Chevy, lowered 3/4", not C notched.
I'm looking at the Hoosier 29x10.5Wx15s, the Hoosier websites says to use a 8-10" wide rim. They have 11.0" of treadwidth, but 13.2" section width.
Fitting a 10" wide rim would be tough w/o it sticking out past the fender. I'm goign w/ a 15x8 w/ 5.5" backspacing.
I have a couple friends w/ 28x10.5x15 ET Drags on 15x10" wheels and they fit, the tires have barely rubbed the leaf springs every now and then.
Old 02-11-2005, 02:09 PM
V6 Bird's Avatar
A W tire on a 8" rim will look silly. It s got 3" over overlap on each side of the weel. Why do you need a W tire anyway? Why not run a normal 10.5 tire? If you run a W you really need to mount it on a 12" wheel for best contact patch. A 10" would work okay but not an 8"
Mike
Old 02-11-2005, 03:11 PM
FIREHAWK #07's Avatar
If you compare a hoosier and a MT slick..... the hoosier is a little bit wider... sort of like Nitto 315's and BFG 315's.... the Nitto 315's are not as wide....
Old 02-11-2005, 03:22 PM
5w20's Avatar
i noticed that as well
Old 02-11-2005, 06:59 PM
eric01ss's Avatar
the truck has a 4/6 drop on it and it is not tubbed
what if i roll the inner lip
Old 02-12-2005, 03:35 PM
foxspy's Avatar
The 29x10.5Wx15 Hoosiers are the same dimensions as the 29x11.0x15s, just different label.
Right now I just have 28x11.5x15 ET Streets, I might just switch over to the ET Drag.
Old 02-12-2005, 06:03 PM
eric01ss's Avatar
thanks for the info man and my trcuk should be done by the end of the year
look at my sig
Old 02-12-2005, 06:37 PM
foxspy's Avatar
What are you goals for it?
What have you done for suspension/tranny/gears/etc?
The track opens up here next weekend, hopefully I get some 7.5xs on motor.
Quick Reply: what is the biggest tire i can fit ?
