BFG Drag Radials ?
BFG Drag Radials ?
Anyone tried the BFG DR's ? How do they hold up on the street ? Reading on tire rack, they mention that they could blister at sustained high speeds which made me a little leary about using them on the highway. Any comments ? Suggestions ??
Thanks
Thanks
They do work good at the strip but not for daily driving. Lets just say I had a pair up until the point where I picked up a nail in one of them . You'll be picking up a bunch of debris that you don't want on your tires. I found that out the hard way.
Originally Posted by Mike TexaSS
I have 315/35/18 GFORCE BFG Drags and they broke my trans!
I run them on my car. They work great on the street IF they are heated. I have not tested them at the track yet. They definitely pick up a lot of debris and i have some blistering from doing 160+ on them.
I bought some used (wouldn't pass inspection then!) BFG DRs spring of 04 then put over 10,000 miles on them on the street and my stock engine impala SS got into the 1.6s in the 60ft and 12s with them. Then I drove home on them
I ran them on my daily driver trans am. They hook alot better than nittos on the street, but i have flown off the highway countless times when was barely wet. Nittos are better for a daily driver for that reason.
I also had BFG DR's on my daily driver and I went through a pair about every 4 months. I put about 450 miles per week on the car. But they hooked like a **** with or without a burnout. They'll hook alot better than Nitto's, but Nitto's will last alot longer though. You gotta give alittle to get alittle.
8 Sec Tuner
Originally Posted by MAXIMO
Are you shure that was what caused it or if was it hard shifting. Usually they will break your rearend first unless the tranny is gonna go. broke my rear end with some drag radials. My tranny is still good.
Vette rears are not glass like an f-body
