need help evaluating these pics PLEASE HELP
And i have a SES light for a cylinder 3 misfire....from the looks of my spring(which is on cylinder 3) i came to the conclusion that the misfire is due to a cracked spring.....but seeing how i'm not exactly a mechanic or car expert...i need some opinions from these pics...you can see that all the other springs are lined up except the one on cylinder 3....if it is a cracked spring, which i do hope thats all thats wrong, im just gonna go ahead and replace them seeing how im eventually gonna throw a cam in there....while im in the motor, what else should i go ahead and replace in order to prepare for a cam ...yeah i know im a noob, but noobs just need a little education sometimes....if anyone could point me in the right direction it would be greatly appreciated...and if decide not to work on the car myself, anyone have any ideas on how much labor would cost for the cam-preparation? thanks in advance guys..hoping to hear some quick replies because i wanna try and get this done before i have to go to work....
oh btw...i plan on eventually throwing something like a 224/224 cam sooner or later
so far im looking at http://www.lmperformance.com/6388/1.html ....but im wondering if i should go ahead and do this without replacing my cam at first..
or the MTI Valvetrain package
well I cant really see anything from thepictures, if the rocker is at an abnormal angle try to see why, is the bolt loose? just look at the spring and see if its cracked at all. Dont know if it would be line a hairline crack but I would think you should be able to see a problem with the spring.
Did you get on it with the engine real cold?
Stupid question, but are the push rods still in the motor and the rocker arms tight? cause if so that rocker that is different from the rest is probably on ther cams lobe and is supposed to be like that. the rockers move when they are on the lobe causeing the rocker to push down on the spring.
NOW if you take off all the rockers and one spring is lower than the rest THEN you have a problem.
alright well i'll be taking the car apart again tomorrow to see what lies beneath the rockers and see if it is a spring or not....anyone in the pasadena area that would be able to lend me a hand and help evaluate what could be going wrong with her...the numbers 832-794-1213..
Drew, SUX2BU is asking you if you looseneed any of the bolts on the rockers, or if you just took the valve covers off to look at stuff.
Mike & Crew do good work, take it over there and they can help you out.
i know the quality of work they do...they fixed my car with my last misfire.....i was just trying to save some cash and try and fix her myself.....this is too wierd though, the SES light will be on sometimes, then will turn off.....i dunno....i'll more than likely be bringing the car up to G-force this monday, coz i need her to get to and from work this weekend.....so...i'll see you on monday Mike, lets see if we can put an end to this damn headache......i'll get back to you after i see how much i have in my bank about the cam install as well....thanks a lot for all yalls help every1
