which cam would u guys choose?
Ok guys which cam would yall choose for a and A4 with a 4k stall
1) Ms3 237/242 .603/.609 113 lsa
2) F14 232/234 .598/.598 112 lsa
3) Custom 238/242 .605/.610 113 lsa
4) Custom 232/234 .600/.602 112 lsa
5) Custom 240/246 .607/.612 112 lsa
So which one guys
So which one guys
9 Second Club NA
T-ReX 242/248 .608/.612 110. Ultimate cam for stock heads. This cam took me into the 10.30s with stock heads naturally aspirated. The only thing I had done to the bottom end was a set of rod bolts. I have one for sale by the way. It has 25 passes on it, no street use, $300. I'll meet you up since we're close to each other or can ship it to you for an extra $10. Let me know, thanks.
dude juss get the t rex and be done with it..i started with the w1 cam from speed tek went 6.9 on motor 346ci..then i went to the magic stick and went 6.70's..then went to the t rex wich is also my current cam and went lower 70's...bigger in my case has been better...i have stock heads also
9 Second Club NA
Went 6.50s in the 1/8th and 10.30s in the 1/4 with this cam. The fastest cam only car has the T-Rex. It's proven. I picked up 35 rwhp with this cam over my MTI C2 cam. Again, the ultimate cam for stock heads. I know I could of dipped into the 10.20s with the weather that has been around for the past couple of days. $300 for the cam. I have a set of 7.4" pushrods as well with 25 passes and no street use for $85.
Ok then but do u guys daily drive ur cars yes or no cus Mti has a package with everything for 699 and can custom grind me a cam which means they can do the trex specs for me if i want so what do yall think
I would it just MTI has a finacne plan i can get that is interest free
I would it just MTI has a finance plan i can get that is interest free
9 Second Club NA
$385 for the T-ReX cam and Comp chromoly hardened 7.4" pushrods. Add a Patriot dual spring kit and you're looking at $610. The kit comes with dual springs good for .650" lift, titanium retainers, spring seats, and Super 7 locks.
I don't daily drive my car, but there's lots out there who do with this cam. If you're worried about gas mileage, that will be dependent on your foot. Any cam will give you bad gas mileage if you're constantly in it.
Where are you located? I see A-town, TX. I'm in Alvin. You'll also save on shipping and there won't be any taxes, keep that in mind too.
