Fender rolling methods?
Old 12-13-2005, 11:06 PM
Slammed-am's Avatar
Default Fender rolling methods?
I recently lowered my car with coilovers and got some of those super fat 315 GSD3's for the rear. I already did the BFH mod. So my fender lip still contacts my rear tires when cornering hard.
I really want to roll the lips up flat
(I don't want to use a fender roller b/c of $$$ restraints and I hear that they are mechanically incapable of rolling the lips completley flat)
So, guys, help me out with some ghetto methods of rolling my fender lips!
I've heard of:
1. Baseball bat method? Can someone explain this in detail?
2. Using Vice grips?? Explain this too, please...
3. Cutting lip into sections then hammering them up? ( I really don't want to use this method)
4. Some strange method of loading the rear and placing an object in b/w so the lips are pushed up under pressure?????
5. Take steriods and do forearm workouts for a year until I can lift my car up and bend the lip up with my teeth?
I would really appreciate any help you can give me. I really want to be able to have my suspension travel as freely as possible without contacting the lip. The offset of my Fikse's (46mm??, 38mm??? not sure...) puts the wheel/tire directly at the egde of the fender (especially with GSD3's) . I sometimes just (eyeballing it) think that even with the lips rolled or hammered or pushed completely flat, there will still not be enough clearance for my tire to tuck in or avoid contact with the fender lip.
Old 12-13-2005, 11:15 PM
TT-TECH Veteran
Inspector12's Avatar
Look don't do any of the ones listed unless you are ready to have some paint work done. PM Nine Ball he has a fender roller I think he will rent it out. It bolts to your axle and has a hard roller to gently roll the fenders as much or little as you want with a heat gun to keep the paint from cracking etc... I helped Crager do his and it worked great and didn't take to long and no real damage.
Jeff
Old 12-13-2005, 11:44 PM
BigSteele's Avatar
i did it the ghetto method and it worked perfectly for me. I used a hammer with duct tape padding onthe head, slowly hammer in sweeps. I used a blow torch (lol) to as a heat gun because i didnt have one. I didnt put the flame on it, just the heat. and I slowly hammered it, replacing the duct tape to keep a padding so it didnt chip the paint, and I was able to bend the lip to just about vertical.
I posted a thing about my experice and put a picture up, I dont have time to search but if you want to see the pics do it.
no paint chips, no bends in the paint etc. just nice smooth fender lip!
edit- heres the pictures I have from doing it. you cant really see it like you can in person but heres something
the electrical tape was put there to check to see if the tire rubs on that part and it dosent
Old 12-13-2005, 11:51 PM
FIREHAWK #07's Avatar
cut every two iches, used vice grips to bend back, then used the BFH.... very small chips of paint came of.... un-noticeable since it was from where i rolled it back...
Old 12-14-2005, 12:35 AM
Brandon Boomhauer's Avatar
Jeff
Thats the BEST method. I do believe Nine Ball rents his Eastwood roller out.
Very nice tool too. Red 01 WS6 has one I believe and his fenders look perfect.
Old 12-14-2005, 07:02 AM
xaon's Avatar
I used Nine Ball's Eastwood roller as well... it came out very nicely.
Old 12-14-2005, 08:24 AM
01 Red WS6's Avatar
The Eastwood Fender Roller works great. I wouldn't use anything else
Old 12-14-2005, 08:44 AM
LS1Tech Co-Founder
Nine Ball's Avatar
PM me if you want to rent it. I also have the heat gun required.
Old 12-14-2005, 05:24 PM
Breakfast Fanatic
Pewter02TA's Avatar
Post pics of ur CAR!!!
Old 12-15-2005, 12:02 AM
DONAIMIAN's Avatar
Do you have a rod ended PHB, one with the good rod ends?
Old 12-15-2005, 02:01 PM
Slammed-am's Avatar
I'll have some up within the month.
Jyeas sir.
Old 12-15-2005, 02:03 PM
Slammed-am's Avatar
Yeah, I got a rod ended one from UMI per your advice. It's centered perfectly, the tires are just too damn fat.
Old 12-15-2005, 02:13 PM
DONAIMIAN's Avatar
yea thoes tires are big as **** for 315's. When are you gona be in town?
Old 12-15-2005, 03:40 PM
Slammed-am's Avatar
I'm here now, when are you/everbody else coming in?
Old 12-15-2005, 04:19 PM
DONAIMIAN's Avatar
I shoulda drove down last night. Ive just been too lazy.
Old 12-15-2005, 07:33 PM
A_W_O_L's Avatar
...the tires are just too damn fat.
tires too fat?? no such thing now a girl...that's a different story
Post up after your done rolling, Ive got the same set going on the back of my stock height car VERY soon...I plan on lowering it shortly after.
Old 12-15-2005, 11:11 PM
chevy42083's Avatar
I've used the wooden bat method, worked pretty well on an S10 and a CTS.
Basically, you use two people. 1 to drive, the other to hold the bat. Put the bat between the wheel and the fender, and apply pressure. Then have the person SLOWLY roll the car forward to the bat will roll it's way down the fender. Use a wooden bat (softer, less chips). Although, this won't work if you don't have enough room between the fender and wheel.
Although, the tool probably is the better way.
Old 12-16-2005, 04:13 AM
((((((Administrator))))))
CRAGER's Avatar
The Eastwood tool that Tony has works badass! And thanks again Tony for the use of it, and thanks Jeff and Joe for helping me out.
It helps to have two people working it, one rolling and one using the heat gun at all times.
Peace,
Craig.
Old 12-16-2005, 12:32 PM
NVR4GET's Avatar
Well if you take a 60lb sledge hammer to the back fenders and hit as hard as you can then you will be good. It works trust me!
Matt
Old 12-16-2005, 01:52 PM
SSilverSSurfer's Avatar
i need to do this too...anyone want ot help me if i rent tonys little kit? damn fender is cutting the sides of my tire
Quick Reply: Fender rolling methods?
