Inspection Woes (ebrake) - can anyone help?
Old 12-29-2005, 02:47 PM
nomorews6's Avatar
Default Inspection Woes (ebrake) - can anyone help?
I need to get my car inspected and such. I am certain that the problem is because my ebrake is loose - it doesn't have the button that pops out. Is anyone around the Houston area willing to take a look at it to see what it'd take to fix it so I can pass inspection?
Old 12-29-2005, 05:58 PM
SUX2BU's Avatar
Didn't know you needed an E brake to pass inspection.never seen anyone check that either.
Old 12-29-2005, 06:33 PM
nomorews6's Avatar
well, the brake light is on in the dash - do you think that matters?
Old 12-29-2005, 07:15 PM
sleepersilverado's Avatar
well you must have a ebrake to pass.
Old 12-29-2005, 10:04 PM
SUX2BU's Avatar
nope. as long as the SES light isn't on your golden.
Old 12-29-2005, 10:10 PM
G5TA's Avatar
Actually the brake light cant be on or it will fail. But if ts the ABS light its ok.
Old 12-29-2005, 11:22 PM
96-speed's Avatar
If the Ebrake light is on then the sensor "thinks" the ebrake is engaged. Pull the console and you can depress it with your finger and test it.
Ryan
Old 12-30-2005, 07:28 AM
nomorews6's Avatar
well in the dash all it says is "brake" I think that is for the ebrake right?
Old 12-30-2005, 10:13 AM
LS1LUNATIC's Avatar
correct
Old 12-30-2005, 10:43 AM
nomorews6's Avatar
for the button under the console - is it easy to see or what should i be hunting for?
