Rear End question
Rear End question
i have a 2002 T/A with an M6 and my rear end is making a howling noise, also there is a heavy vibration in the passenger side of the car. I know these rear ends are crap from the get go but im trying to decide weather to take it to a dealer and just have the stock parts replaced in it. or should i take it do a performance shop and go that direction with it. I hate to spend the money on a rearend set up that I know was junk when it came from the factory but i was wondering what the cost would be for the performance route.
thanks
Justin
thanks
Justin
i would od a 12bolt...my rearend was making howling and i checked it and the pinion nut backed out. so it could be anyhting with your...vibration might an unbalanced drvieshaft
I'm saving up for a 9", myself. If it's a daily driver and you MUST get it fixed to get it back on the road, that's one thing, but if you've got the means to wait and get a 9", go for it. Spending money on upgrading a 10-bolt just doesn't seem worth it to me, if it can be avoided. That's just my opinion, though.
-Mike
-Mike
I'm in a similar situation, except no vibration. Stock 3.42 on a 99TA. It's making a faint humming sound and there is a lot of metal particles in the rear end lube.
I added a magnet to the fill plug and am going to put new fluid as well as a few magnets on the inside to hopefully make it last longer.
It is a daily driver and I don't have another car so I plan on fixing it, not replacing it. Are there any cheap rearend guys in the Houston area?
