Great set of budget big cube/cam heads
Heads are 317 castings and come with 2.02/1.60 Rev standard length valves, port work done by me. Intake runner is rolled finish, comb chamber and exhaust runner are polished. Deck has been surfaced, just to ensure true ~005. Intake runner volume is about 236cc. Flow numbers are listed below.
Intake Exhaust
.200 151 114
.300 210 157
.400 253 180
.500 293 206
.600 315 212
.700 318 216
Flow numbers came from Trevor Johnson cylinder heads. He has no allegiance to me and will confirm flow numbers if necessary. I have the flowsheet in PDF format for the purchaser. Heads come with valves and you supply your valve springs/retainers. If you need it, I will install your hardware at no additional cost. Make no mistake, these flow numbers are dead on, not like many of those shops that claim numbers like this and fall 10cfm when on the actual bench. $950 shipped, $900 picked up in the Garland area. 469-387-2576.
Brandon
Intake Exhaust
.200 151 114
.300 210 157
.400 253 180
.500 293 206
.600 315 212
.700 318 216
Brandon
Originally Posted by turbo'd stang
Nice flowing head. Should be able to make some power with those.
Brandon
