Tranny grenaded and driveshaft broke @ 130mph
Old 03-11-2006, 10:34 AM
1badV6's Avatar
Default Tranny grenaded and driveshaft broke @ 130mph
I was on my way to Ft.Worth from Houston yesterday coming up for the weekend. My buddy was following me on his Suzuki 600 and we decided to do a little racing. I started in 3rd @ about 4300 rpm and put it to the floor. Banged 4th and kept on pullin. By this time we were side by side and I thought what the hell let's hit 5th. Stuck 5th and I was doing about 5500 to 6000 rpm's. Just as I was about to let off it sounded like a shotgun went off right beside me. After the loud *** bang I emediately let off. At this point smoke started coming in from the console area. I slowed down gradually because I didnt know what the **** just happened. Once I got it over on the side of I-45N i went to put in neutral and felt nothing. I looked down and the shifter was crooked as hell and all my stuff in the console was thrown out with the bottom of the console being shattered. I step out and I found a trail of tranny fluid all the way down I-45. I looked under the car and found no drive shaft, both mufflers beat to ****, maybe my torque arm and my trans bleeding like a stuck pig from the drain hole under the slave. I havent got a chance to see what else is ruined. I walked about a mile back and found only half the drive shaft snapped in half on the shoulder. In have a cam only, spec 3, 12bolt w/ steel drive shaft. What do ya'll think would of caused this? Good news is motor is fine I think and I have extended warranty hopefully covering some of the problems.
Old 03-11-2006, 11:06 AM
LS1powerhouse02's Avatar
damn dude.....that sucks. Sounds like it was scary as hell! I know i would have **** my pants! Hope you figure it all out!
Old 03-11-2006, 11:12 AM
BBADWS6's Avatar
Damn, atleast you are ok, broken driveshafts can cause some serious problems.
This is a demonstration of how important drive shaft safety loops are.
Good luck with the trans rebuild.
Old 03-11-2006, 11:18 AM
mellowyellow's Avatar
No **** , But is'nt it hard to fit one with True Duals ?
Old 03-11-2006, 11:23 AM
97blkz's Avatar
Happened to me when I snapped my drive shaft at 80 mph the car skipped up in the *** end, I know have a DSL. I had holes in my floor boards bullets trashed and other damage!
Old 03-11-2006, 12:07 PM
z06matt's Avatar
Ouch man... yeah Nick was telling me about this last night. Sorry to hear... Good luck getting it all back in shape.
Old 03-11-2006, 12:10 PM
842ta's Avatar
Glad to see the 12 bolt made it out alive I just now got done paying that thing off!!!!
Old 03-11-2006, 12:35 PM
NickcZ28's Avatar
Dont worry about it man!! Ill get it taken care of... I didnt think that V6 made enough power to break anything??It barely breaks the tires loose!! HMMMM...
Old 03-11-2006, 01:03 PM
z06matt's Avatar
That's just wrong
Old 03-11-2006, 01:07 PM
DONAIMIAN's Avatar
I agree, either that or a carbon driveshaft.
I dont think it was the tranny that let go, I just think that driveshaft hit its critical speed, or a U-joint failed. Steel driveshafts dont like a lot of speed at all.
Old 03-11-2006, 01:13 PM
NickcZ28's Avatar
thats what I am thinking also, I think it had to do with the harmonics at high speeds.. I dont think the tranny would just blow up!!
Old 03-11-2006, 01:19 PM
joeformula's Avatar
Damn what a bummer!
Old 03-11-2006, 01:43 PM
1badV6's Avatar
My next mod will definitely be safety loop along with whatever else broke. I think it was the driveshaft, it pretty much snapped in half with a very clean break.
Old 03-11-2006, 02:30 PM
DONAIMIAN's Avatar
I would just get a really good aluminum (PST, Dennys) shaft next time. It cost a little more, but would be well worth the investment.
Old 03-11-2006, 02:34 PM
1badV6's Avatar
How much do they cost? Wouldn't steel be stronger?
Old 03-11-2006, 03:13 PM
NexGen's Avatar
I personally like the steel ones better. Too bad to hear that about your car. That must have made you **** your pants!!
Old 03-11-2006, 06:51 PM
Brandon Boomhauer's Avatar
denny's nitrous ready
you break it, they send ya a new one
you need it balanced, shortened, new ubolts or whatever, they do it for free labor and cost of materials.
at least i read that on their site...
Old 03-11-2006, 09:21 PM
slowpoke96z28's Avatar
what kinnd of pinion angle you run? thats suprising that an aftermarket steel driveshaft broke. i've heard/seen broken alumunum ones, but not steel. i know thunderracing has every style or driveshaft from steel to carbon fiber. i'd call them and see what they think. and not to be a bummer, but be prepared for the warranty to not cover this. a-lot of extended warranty companies have a no mod clause in their contracts, and the ones that dont will try every trick in the book to weasel out of having to give up the money. if you have GM's extended warranty, you have a better chance than with the "bootleg" warranty companies, but its still not a 100% certainty. FWIW, the local salvage yard will have what you need to get the car back on the road, and for cheap, if the warranty thing doesn't work out.
Old 03-11-2006, 09:22 PM
1936FordPU's Avatar
Nope..I can build around a Lakewood loop very easily.
Old 03-12-2006, 02:12 AM
SSilverSSurfer's Avatar
damn sounds scary.....hope you get everything fixed
Quick Reply: Tranny grenaded and driveshaft broke @ 130mph
