changed pads and caliper won't go on...
same thing happened to me. i found that the rubber flex boot was missing on of of the bolts, so water got in a rusted it shut.
had to disconnect the caliper and torch the bolt/surrounding area and press it out with a vice. thing was STUCK in there and i mean STUCK.
the new bolt/boot assembly from the GM place was like 8$ for a bolt. it was also their last one in stock. if this is your same problem might want to make sure they allready have one there if they have to order.
then again, when mine blew i was in a really small city but whatever.
goodluck.
t
goodluck.
t
I had mine get STUCK like a sob. Both were actually. I had to get a blow torch and heat it up around the bolt. Took nearly an hour of torch and pry, torch and pry but it eventually came out
try that
try that
Just use a torch to heat it up. Mine did the same thing, I didn't have a torch at the time so I got a new bracket since I needed the car running but once I got it all done I borrowed a torch and it came out. I had an extra guid pin sitting here so I threw it in with some grease and it's good to go back on the car just incase I have the problem again. FYI Passanger and Driverside brackets are exactly the same
