can someone in san antonio help me? (electrical diagnosis)
Old 06-23-2006, 10:36 PM
josh18_2k's Avatar
Default can someone in san antonio help me? (electrical diagnosis)
i started a thread in the PCM diagnostic section but so far it hasnt been any help.
i just put an ls1 in my rx7 and it wont start- long story short, i have spark and 12V to the injectors' pink wires, but the injectors dont fire when cranking. obviously, its something electrical. everythings plugged in and the PCM was tuned by jesse bubb (he appears to be the real deal based on my reading...)
so if anyone locally is knowledgable about diagnosing this kind of thing, i would really appreciate the help.
~Josh
josh18_2k@hotmail.com
Old 06-23-2006, 10:38 PM
Kewl_Blades's Avatar
crank position sensor?
Old 06-23-2006, 11:37 PM
M6Z28's Avatar
try the conversions and hybrids section
Old 06-24-2006, 12:49 AM
kornfreak_401's Avatar
props to ur hard work on ur car, but why go thru all the trouble? why not just by a f-body?
Old 06-24-2006, 08:44 AM
josh18_2k's Avatar
i love rx7's for the handling, brakes, weight, and appearance, and of course everyone loves v8 power. its kinda the best of both worlds. i didnt build the car for drag racing. my engine is stock and it'll probably stay that way. i did it to make a car that handles really well but has the horsies to back it up. that, and the total price of my car is still cheaper than a late model f-body.
back to the issue- as far as i knew, if the crank position sensor was messed up i wouldnt have spark (according to another thread). when cranking, it sparks at regular intervals.
Old 06-24-2006, 09:05 AM
josh18_2k's Avatar
would someone in town at least be willing to swap PCM's with me? ya know- see if your car runs with my PCM and vice versa. i guess your car would have to be 99+, manual, and not too far from stock. i'm available everyday after 3pm, and all day tomorrow (sunday). i need to get this figured out asap (moving to oregon in less than a month and i was going to drive there...)
also, if someone has of those tuners to read my engine codes that should help too.
(210) 875-4658
thanx
Old 06-24-2006, 11:05 AM
11SECDWS6's Avatar
~Josh
I would start by checking all your grounds. An easy mistake to make when replacing an engine. Been there, done that...
Old 06-24-2006, 12:41 PM
AGRV8D's Avatar
go to lethal performance.... ask for danny or joe
Old 06-24-2006, 01:11 PM
josh18_2k's Avatar
my engine has two 4ga ground straps (one on front of drivers side head, one on back of pass side head), and i grounded every wire the was hanging out of my harness. my pcm connectors' #1 pins are both grounded, and the injector plugs show 5.5V across the terminals with ign on. they just arent firing.
i'll look up lethal, but if an f-body owner around here is willing to donate some of their time that would be great too.
Old 06-24-2006, 02:15 PM
AGRV8D's Avatar
they are located by rolling oaks mall
210 656 5220
Old 06-25-2006, 09:52 PM
josh18_2k's Avatar
can someone in town please come help me out- if nothing else, i'd like to at least stick my mulitmeter in someone elses car and see whats 'supposed' to be happening at the injectors.
