!?Gas!?
Old 07-17-2006, 09:37 AM
dps_ls1's Avatar
Default !?Gas!?
What kind of gas do you use in your car during regular street driving?? I was told I was crazy because I put the cheap stuf in and if I am gona go race or somthing I put octane booster in.
Old 07-17-2006, 09:48 AM
BC 01 SS's Avatar
i always put 93 in, never anything less
Old 07-17-2006, 09:49 AM
chupr0kabra's Avatar
Premium only. 87 octane can lead to detonation (not to mention crappy mileage). Detonation can lead to a rod escaping via the hole it will make in your oil pan.
-Mike
Old 07-17-2006, 09:51 AM
Hagarr's Avatar
93 only
B
Old 07-17-2006, 09:52 AM
chadtx01's Avatar
I always run 93.
When I buy gas and its the ethenol blend, I run octane booster. I know it does nothing, but it makes me feel better and it wastes another few bucks.
Old 07-17-2006, 09:56 AM
TWS
TWS's Avatar
Open your fuel door. Read the sticker there. To save you time, it says "Premium fuel only".
Yes, our cars have knock sensors, yes, they will remove timing once knock is detected, but you can still damage the tops of your pistons or even rods.
If you are running around on 87 octane, what happens if you suddenly need to romp on the throttle? Detonation happens, that's what. Hell, in this hot weather, you could detonate at part throttle on 87 octane.
Octane boosters are largely snake oil. That means they don't work. This has been tested by car magazines and consumer reports.
Sometimes I alternate a tank of 89 with a tank of 93 in my wife's car because she doesn't ever WOT it. I would never put 87 in it.
Old 07-17-2006, 10:26 AM
D Hurr is Like's Avatar
Strictly 93 here as well
car has never seen anything else
Old 07-17-2006, 10:43 AM
treysoucie's Avatar
93 only, here.
Old 07-17-2006, 11:05 AM
lt197formula's Avatar
93 is the only way to go
Old 07-17-2006, 11:08 AM
longrange4u's Avatar
Ummm 104??? Ok Ok... 93 with a cocktail when racing.
Old 07-17-2006, 11:09 AM
00T\A's Avatar
93 only.
Old 07-17-2006, 11:26 AM
Saad06's Avatar
shell V-power for the winner! it's 10% ethonal but i've never had a problem, always clean and burns well. also, i use Chevron's fuel system cleaner (techron) every few tanks. my car was ran with midgrade or lower before i bought it, did the techron thing a few times and it imporoved alot more, picked up a little gas mileage also.
-Saad
Old 07-17-2006, 12:19 PM
treysoucie's Avatar
i would never floor my car if i had any less than 93 octane... hell, my moms durango detonates if it has 89 octane and you get on it.
Old 07-17-2006, 12:22 PM
daniel6718's Avatar
93 always...this should be a poll...think it would be 100%
my friend used 87 till he realised it was cheaper to run 93 bc of gas mileage, the retard you get from 87 wasts mileage/efficiency...do i see no reason why to use 87 it costs more for goodness sake...
Old 07-17-2006, 01:30 PM
1 last 1's Avatar
Only Shell, Chevron, or Exxon 93!
Old 07-17-2006, 02:00 PM
Pwebbz28's Avatar
Damn tight ***! Its only 20 cents more a gallon. On a 15 gallon tank thats only 3 bucks. Eat some ramen noodles once a week instead of buying lunch if you wanna be tight
Old 07-17-2006, 02:25 PM
Morbid's Avatar
93 octane, street or strip.
Old 07-17-2006, 02:31 PM
98 Raptor TA's Avatar
If you run anything but 93 you'll do nothing but cost yourself more trouble and money in the longrun.
Old 07-17-2006, 02:36 PM
Moderator
BizZzatch350's Avatar
The 93 gets 93 The Blazer gets 87
Old 07-17-2006, 02:46 PM
turbols1_05's Avatar
89 or 93 here
