what does abs mean?
Old 08-06-2006, 05:39 PM
volcanic2345's Avatar
Default what does abs mean?
my abs inop light was on in the bottom left of my car 2002 camaro what does it mean thanks!
Old 08-06-2006, 05:46 PM
Donohue96M6Z28's Avatar
abs= antilock brake system? one time my light came on, and i added some brake fluid and it came off. i think it was just a coincidince tho
| Powered by Satan |'s Avatar
antilock braking system
check your brake fluid level, it might be low
wow, we posted the same thing at the same time :o
Old 08-06-2006, 06:41 PM
wickedrx7's Avatar
Maybe a wheel sensor is out or ABS module. When the ABS light comes on the ABS is automatically disabled. Your brakes should work just fine, just no ABS. If your brake fluid is low, the brake light will come on (the same light will come on when you pull your emergency brake)
Old 08-06-2006, 06:54 PM
well it went off like 20-30 mins later i will check everything out but its not on anymore!
Old 08-06-2006, 07:47 PM
SHINER's Avatar
arent you the guy that was calling out all these badass drag cars earlierand stirin up trouble?....and you dont know what ABS stands for..??
Anyways it means Anti Lock Brakes, and sometimes like if you dyno ur car and senses if the front wheels arent moving and there rear wheels are moving itll set it off. OR when ever u have to stop ur car abruptly it might set it off. Make sure its filled properly to ensure it functions properly.
Hope that helped, later.
Travis
Old 08-06-2006, 07:54 PM
Travis
yeah but iam still learning about ls1s, i love them and want to know anything i can, thats why iam here thanks!
Old 08-06-2006, 07:59 PM
SHINER's Avatar
no prob hope i helped. Take it easy.
Old 08-06-2006, 09:25 PM
98 Raptor TA's Avatar
Travis
yeah, when i got my TA dyno'd i was about to leave and i was like WTF why is my brake light and ABS inop on? and the dude at the shop was like it's just from the dyno run, and then i thought about it, and felt stupid cause i should have known it was just something dumb like that.
Old 08-07-2006, 09:41 AM
MAXIMO's Avatar
I dont know but i think volcanics cars dont have ABS. with the exception for the 2002 and the blue camaro on his sig.
Old 08-07-2006, 10:19 AM
mcowart's Avatar
i dont have abs....my light stays on but its bc of my 4 channel rear
Old 09-10-2006, 08:11 PM
cjels1's Avatar
damn my ABS INOP and BRAKE lights are both on, hopefully its just my fluid level
Old 09-10-2006, 11:18 PM
DONAIMIAN's Avatar
If its a wheel speed sensor its mostlikley the rear, its mounted on top of the Diff. You can still use the brakes but as long as its on the electronic porportioning valve will heavily bias the rear brakes. That means not hard stops at speeds above 40 because the rear can, and will lock up causing you to loose control.
