6.2L heads
Old 08-09-2006, 12:32 PM
1LSWON's Avatar
Default 6.2L heads
How do they flow? Do I have to use a LS7 style intake or can I use my fast? Please help me out. Im looking to get new heads done for a 402.
Thanks,
Thomas
If I have to use an LS7 intake how does it flow compared to a fast? Or should I go with the carb style intake?
Old 08-09-2006, 12:59 PM
zigroid's Avatar
https://ls1tech.com/forums/generation-iv-internal-engine/499059-ls3-l92-info.html
Old 08-09-2006, 01:00 PM
Stang's Bane's Avatar
You can't use a LS7 or the Fast. You have to use the L92 intake. It is just becoming available now. No-one really knows how it flows yet, we are all waiting to find out. But FWIW the LS7 outflows a Fast 90 real bad.
Old 08-09-2006, 01:28 PM
DONAIMIAN's Avatar
Yup, the LS7 intake outflows the fast by a good amount. Id miagine the L92 would outflow the fast as well. The L92 heads flow 330cfm out the box I belive and theyre dirt cheap compared to everything else out there.
Old 08-09-2006, 01:32 PM
| Powered by Satan |'s Avatar
402 eh T
Old 08-09-2006, 01:33 PM
SSilverSSurfer's Avatar
so what would use if you cant use FAST, LS7, and the L92 is barely becoming available?
Old 08-09-2006, 01:34 PM
DONAIMIAN's Avatar
Sheet metal
Old 08-09-2006, 01:37 PM
Originally Posted by DONAIMIAN
Sheet metal
uh son!!!!
Old 08-09-2006, 05:04 PM
00'WS6Rocket's Avatar
Sheet metal
Old 08-09-2006, 05:50 PM
kickassT/A's Avatar
sdpc is supposed to have some of the aussie intakes coming. the l92 won't fit under the hood of an f-body. i've also heard rumors about a carb intake, but nothing definate.
Old 08-09-2006, 08:25 PM
skipperbisket's Avatar
i talked to SDPC monday about this and was told that with those heads you'll have to get different rockers, and a custom intake manifold. i would LOVE a set of L92s and a single plane like the vic. jr. i'd buy that **** up in a heartbeat.
Old 08-09-2006, 09:02 PM
1LSWON's Avatar
Thanks guys if they flow what I hear Im getting them. What size in the TB that mates up to the intake?
Thomas
Old 08-09-2006, 11:18 PM
BigBronco's Avatar
90mm TB..
Got a set being worked on @ work as we speak
Old 08-10-2006, 04:07 PM
HEMIETR's Avatar
I believe the exhaust rocker is the same as a LSx. The intake uses an offset rocker. Someone correct me if i'm wrong. Strange though, the exhaust rocker cost way more than the intake.
Old 08-10-2006, 07:08 PM
UGotBeaT's Avatar
id start working on my 6.2's but dont feel like spending 700 bucks on custom valves and i dont wanna buy the stock valves
