Finished my front suspension set up
Old 08-10-2006, 11:47 PM
9 Sec. Club!!!
dan03mach's Avatar
Default Finished my front suspension set up
Finially finished my front suspension.. I installed a D&D K-member, A-arms, Coil overs with 250lb springs, Maximum Motor sports 4 bolt Caster/Camber plates, KYB AGX adjustable struts, and sway bar.. I had a few issues with the D&D K-member rubbing on the steering shaft but that is going to be taken care of, also my passenger side header is touching the K-member.. I think I hammer can take care of that or the plasma cutter I will see which once I want to mess up.. So far it feels great, the supsension is a hell of alot tighter and can take some awesome corners.. I feel like I have better control of the car now on the road.. Handling is 100% better. I also lowered the front end about 1/2-3/4 of an inch.. It looks good now but I think maybe another 1/4 inch would look a little better.. At least now it doesn't look like the rear is lower then the front. Now I just need to get everything alligned..
Old 08-11-2006, 12:17 AM
SSilverSSurfer's Avatar
still gonna pull the wheels?
Old 08-11-2006, 12:25 AM
9 Sec. Club!!!
dan03mach's Avatar
It should with no problem.. I was pulling them N/A on N20 with the stock suspension.. This stuff if alot lighter.. We will see.. I'm going to try to take it to Kennedale for some TNT Next Wed. I'm going to be racing in the street car shoot out at Ennis on the 19th. So I need to dial everything in..
Old 08-11-2006, 12:33 AM
good luck out there dan, i would love to make it up there and check it out but i wont be able to
Old 08-11-2006, 12:37 AM
9 Sec. Club!!!
dan03mach's Avatar
Thanks alot man, I'm going to enter in all 3 of the index classes to try to win 600 bucks 200 per class.. If I win one that would be great.
Old 08-11-2006, 08:01 AM
V6 Bird's Avatar
2" Wheelies are the ****. I used to do that on my Huffy.
Old 08-11-2006, 09:05 AM
9 Sec. Club!!!
dan03mach's Avatar
Yep thats right.. At least I have a car running that can do it.. What happened Mike? You got banned on LS2 forever for all your **** talking so now your trying to bring it over here.. Good luck with that.. HAHAHAHAHA
