Need Wolfe bar welded in DFW
like the title says. i need to get a wolfe swaybar welded into the TA soon and CHEAP. i have some other things that need welding exhaust and other junk, but the swaybar is the most pertinant at this point.
Originally Posted by red90cobra
think he needs the brackets for the the swaybar welded on
damnit matt, just call up the dr.
or the post above, either can/should set you up.
but first, get a damn motor ready.
Originally Posted by mitchntx
You need a sway bar welded? To what?
If it broke, you need another one. The heat from welding will take all the tensile strength out and it will not perform as it should.
Come on now mitch..this is drag racing here buddy.
Originally Posted by Kewl_Blades
you don't weld swaybars...
you need linkage to attach to your TA
Massengil, Summers Eve or store brand?
http://www.wolferacecraft.com/detail.aspx?ID=217
you weld this swaybar. how the hell would you connect it to the torque arm?
they are both connected to the rearend. sorry, im really really confused on your post.
Originally Posted by Brandon Boomhauer
do huh?
Originally Posted by FireHawk178
These are welded to the frame rails..
I would call Lindon. I'm guessing he's the guy that used to work for Wolfe?
If it's his old style then it's pretty easy, the newer ones look nicer but take a little more effort. Still though anyone fairly well versed with a welder should be able to install it for you.
Mitch: you'd probably call it more of an anti-roll bar than a swaybar. It's a solid bar that rides inside of a couple of bushings then it has tabs on each end connected to rod ends, connected to tabs welded on the axle housing. It slightly preloads the suspension and won't let the rear suspension twist at all. Kind of like a really thick conventional swaybar but it doesn't affect up and down movement. With a torque arm setup it gives the same advantages as having ladder bars.
do huh?
Originally Posted by V6 Bird
Which brand of douche do you like better?
"Our REAR SWAY BAR is welded between your stock frame rails and is connected to your rear end with spherical rod ends. Unlike most stock sway bars, which are attached with rubber bushings or to the suspension control arms. The attachment with the spherical rod ends ties directly the sway bar into both sides or the rear end housing."
Oh ... it's mash the gas and hang on kinda thing ... no driving required.
