im desperate, i need rotors!!!!!!!!!
my back rotors are shot, i need to get some asap. i was going to go with those centric rotors, all four for $150, but those guys have not pmed me back yet, so does anyone know where i can get drilled rotors, all 4, for around the same price or a little more. i need these asap.lmk
Check these from WS6 store. They’re cheap. I didn’t try them, so I don’t know about their quality. They are Slotted/Drilled.
http://www.ws6project.com/user_stor/...41e51cd22635db
The WS6 store rotors are light castings. Stock fronts are 16 lbs, and theirs are 16.5 lbs IIRC. Even the cheap Autozone rotors weigh in at 18 lbs.
I personally wouldn't run drilled, but I'm not in it for the bling.
Hey Josh it was good to run into again this weekend. Since you didn`t get the rotors you said you were getting I`m glad you didn`t. Go with light weight non- drilled or slotted rotors and some brake pads that I will recomend if you PM me. They will give out alot of break dust but stop on a dime if you seat the pads right. The pads I`m talking about need to be warmed up befor they work right, but all you need to do is pump the brakes a few times with your left foot while you accel. befor you hit the corner. It all depends on your car weight for the pad you choose, and like you told me and littel Al you like to corner. Hey Josh the car is looking sweet.
