steering wheel vibration
Old 09-11-2006, 06:16 PM
TX_SS's Avatar
Default steering wheel vibration
my front end vibrates like ****; starting around 70mph. i just got my wheel/tires balanced/road forced and it still vibrates hard. now only thing ive changed is the front brake pads and rotors. but it does NOT vibrate when im braking. only when im cruising or accerlate. what could be wrong?? any suggestions?? what could cuz my front to vibrate??
Old 09-11-2006, 06:24 PM
Morbid's Avatar
Bad tire(s)? Maybe a knot in one of them or something.
Old 09-11-2006, 06:28 PM
ROCNDAV's Avatar
Have you checked your upper/lower ball joints?
Old 09-11-2006, 06:56 PM
TX_SS's Avatar
just got new tires last week..
Old 09-11-2006, 07:01 PM
Brian2006's Avatar
ball joints.
Old 09-11-2006, 07:14 PM
mukyluk's Avatar
get your tires re-balanced. one of the weights mgiht have come off . after that replace your ball joints
Old 09-11-2006, 09:45 PM
sleepersilverado's Avatar
check the lug nuts. and like said before even though they were just balanced dont mean they are still.
Old 09-12-2006, 04:25 PM
98 Raptor TA's Avatar
if you're lowered, the alignment might be off
Old 09-12-2006, 04:31 PM
Brandon Boomhauer's Avatar
pull the wheels off, then put them back on and torque them in a star pattern to spec.
Old 09-12-2006, 07:01 PM
will350wax's Avatar
My experince on the matter is starts vibrating around 70 but stops around 80. If that true for you then it is your tires. May have to buy new ones, or may need balanced. Rotate the back to the front and see if it goes away, but remember back tires could be bad also.
Oh yeah It could be a wheel. Unlikely but possible. I have seen wheels that wouldn't balance. Also if you have a wheel wait in more than one place on either side it is probably not balanced correctly.
Old 09-12-2006, 07:02 PM
red95ssclone's Avatar
I suggest looking at the weights on the wheel. If your Wheel dosent have weights on the outer lip,look on the inside. There should be stick-on weights right behind the spokes. There should also be weights either stuck on the inner-most part of the wheel or hammered onto the inside lip. I use to work at a shop and people would get lazy and only stick on half of the weights, a "static" balance. Things would vibrate like hell on the freeway.
Old 09-12-2006, 08:16 PM
DONAIMIAN's Avatar
Just because the tires are new dosent mean that they cant be seperated.
Also if it starts at 70 and dosent go away it can also be bushings or a driveshaft.
Old 09-12-2006, 08:17 PM
DONAIMIAN's Avatar
Or possibly a bent wheel. Ive made plenty of horribly bent wheels zero out on the balancer, but that dosent mean theyll still ride smooth.
Old 09-12-2006, 08:46 PM
SUTTERERMAN85's Avatar
this is ture and where i put money
Old 09-13-2006, 07:43 AM
V6 Bird's Avatar
He does have a bent wheel. My guess though is that the balance is off too. Just because it zeros out doesnt mean that its correct either. You can throw waits at a wheel all day and eventually it will balance..lol
Old 09-18-2006, 04:03 PM
TX_SS's Avatar
time for new rims..
