Machine Shops around Katy?
I've got a 9" third member I need sandblasted, pinion pushed out of the support, and all mating surfaces machined. Any ideas?
i can do the sandblasting where i work. you just need it cleaned up or what?
depending on the machine work, i might be able to see about throwing it in a machine at work too. if you want to email me some pics my email is rcook@fwgts.com
I do need it cleaned up, but I also need the pinion pressed out of the pinion support, the differential cap mating surface machined, and also to have the new caps themselves machined to the correct bore size. I will send an email or PM once I get some pics. Thanks!
