*FS* or WTT 02 Red WS6
Car is SOLD. I have a 2002 WS6 that I bought new in 02. I would like to test the waters and see if anyone on here would be intersted in a trade or to buy.
My WS6 is in awesome condition. It's ready to cruise the streets, everything thing is in perfect mechanical order, everything from the ac, alternator, pwr door and power windows works great. It has 58k on the clock. Garage kept its whole life. I've maticulously maintained this vehicle since day 1. It has Royal Purple from front to back. The past 12k miles, I've changed the oil every 700-900 miles. The first 46k miles were from commuting to and from college for on the highway. The interior is in 99.9% imaculate condition. The outside is in 95% imaculate condition, only because of some micro rock chips ,etc. I have most of the receipts for aftermarket parts as well as a dyno sheet. The car has a Spec stage 3 clutch and Racetronix fuel pump system, so it is ready for up to 550-600 rwhp if wanted...just add blower or spray. It's lowered 1.5 inches in the front and 1 inch in the rear Here's a list of almost all the aftermarket parts.
TR 224/224 cam
Comp cam beehive valve springs
Titanium retainers
TR chrome-moly pushrods
Pacesetter Long tube ceramic coated headers
Pacesetter Off-road y-pipe
Magnaflow cat-back exhaust
QTP electric cutout
ASP underdrive pulley
Whisper air lid w/ K&N filter
Smooth bellow
Bo White ported throttle body
BG Ram air mod
Spec stage 3 clutch and flywheel
McLeod adjustable master cylinder
Pro 5.0 short throw shifter
Mac performance rearend girdle
HAL QA1 12 way adjustable front shocks w/ spanner wrench
HAL front springs
BMR rear lower springs
BMR strut tower brace
BMR tubular rear control arms
BMR rear control arm relocation brackets
BMR adjustable pan hard bar
BMR subframe connectors
BMR sway bars 32mm front and 21mm rear
Polyurethane engine mount-drivers side
Cross drilled and slot brake rotors front & rear
Hawk performance brake pads front& rear
SLP line lock
RV-Plus Volt Booster
Racetronix plug n play 255LPH high pressure fuel system
SLP manual fan switch
160 degree thermostat
Diablo Predator programmer
MBA “Last of the Breed” Cylinder head plate
OE Concept chrome ZR1 wheels 17x11 and 17x9.5
Optima red top Battery
NGK TR-55 spark plugs
I can get more pics or info if needed. Just let me know if anyone is interested. Thanks
Brian C
TR 224/224 cam
Titanium retainers
QTP electric cutout
Smooth bellow
BG Ram air mod
HAL front springs
SLP line lock
Brian C
Originally Posted by lets_fly
bad azz car, i was wondering where did you get that "last of the breed" plate that is mounted on the head, i would relly like to get one. lmk please.
