F/S 1968 Camaro drag car
It is a 1968 ss camaro
461'' big block
ported oval port heads
flat tappet cam
eldebrock victor jr intake 1170 dominator
powerglide with brake 5500 stall
ford 9'' 4.57 gears
14 point cage
15x12 convo pros goodyear slicks
all steel except hood decklid and rear bumper
It ran mid 10's last time out looking to get $25K
[IMG][/IMG]
461'' big block
flat tappet cam
ford 9'' 4.57 gears
14 point cage
[IMG][/IMG]
More info 461 CID, all machine work done by Conrad Racing Engines in Houston, 13to1 Comp, Comp flat tappet cam, cast crank, Iron heads flow 290 Cfm, weiand aluminum water pump, Victor Jr. Oval port Intake port matched, 1170 Dominator, MSD Billet Distributor, MSD Heli core wires, Hooker Coated 2'' headers, Griffin Aluminum radiator, electric fan, all braided or aluminum fuel lines, 5 gallon Harwood cell, 2 holley blue fuel pumps and regulators, 2 fram canistor fuel filters, Arabie glide, Tci brake, tci 5500 stall, tci shield, tci flexplate, ford 9'',nodular case, strange axles, spool, richmond 4:57 gears, double adjustabe ladders, koni shocks, lakewood 90/10 in front, quarter stick air shifter & bottle, dedenbear crossover, throttle stop timer, msd 6AL, autometer gauges, 14 point cage, car is backhalved, good to 10.0ET tin work is old & shows wear, paint done may of 1999 by owner, car is very straight, all steel except hood decklid and rear bumper, lexan windows.
Any other questions call Tom @ 409-962-5004
BTW The blur LS1 thanks for the post on hot rod gossip
