Can Mach 1's be supercharged with a 03-04 Cobra s/c?
Old 06-04-2007, 12:17 AM
DopeFedZ's Avatar
Default Can Mach 1's be supercharged with a 03-04 Cobra s/c?
I know this isn't a Ford site but I just raced a guy in a Mach 1 and when we pulled up to the light to talk about mods he said it had a Cobra blower on it .
He pulled on me when I was on motor but the next race on dope was ugly .
Old 06-04-2007, 12:28 AM
01FormulaTA's Avatar
yah its possible but it wouldnt just bolt right on......there be quite a few parts that would have to be swapped but yes they are both 32 valve 4.6s that share alot of the same parts.....
Old 06-04-2007, 01:14 AM
2 SLOW's Avatar
this local guy in Austin did it in his red Mach...
Old 06-04-2007, 01:39 AM
Texas Heat's Avatar
I call BS. And I call BS on you even owning a cobra...
Old 06-04-2007, 03:48 AM
Steve C.'s Avatar
it can be done but its not worth it IMHO.
Old 06-04-2007, 07:38 AM
That_guy's Avatar
its basically the same engine but will require some work to get it done. but seriously why would you do that lol , the mach one is a good engine without it imho.
Old 06-04-2007, 09:07 AM
sc1twntrbo's Avatar
they basically bolt right on you just have to do some trimming on the shaker intake to fit over the supercharger. its an easy swap since alot of cobra guys upgrade.
Old 06-04-2007, 09:08 AM
DopeFedZ's Avatar
What a coincidence this dudes Mach 1 was red also.
Old 06-04-2007, 09:09 AM
DopeFedZ's Avatar
Thanks for the replies. I was just trying to figure out it if he was just bs'ing or if it was true.
Old 06-04-2007, 09:57 AM
silver01z06's Avatar
wouldnt a factory eaton be alot of boost for a factory mach1 bottom end?
Old 06-04-2007, 10:02 AM
nickdotcom's Avatar
if hes got the money for the blower, im guessing he's got the money for some new internals
Old 06-04-2007, 10:05 AM
CaseyEaterMach1's Avatar
The stock internals of a Mach are good up until about 8lbs of boost and with the stock pulley the cobra's Eaton delivers 7.5lbs so it should be fine on the mach stock bottom end. Well with a good tune that is a little detonation and that's the end of a rod and your engine too.
Old 06-04-2007, 11:45 AM
Sprayed1998's Avatar
I think it requires swaping to 03/04 heads
2 SLOW's Avatar
http://www.svtperformance.com/forums...d.php?t=383144
he has a lot of pictures somewhere...
Old 06-04-2007, 11:57 AM
LS1Aggie09's Avatar
so the mach motor doesn't have forged internals? what is the difference between the mach and cobra motor then?
Old 06-04-2007, 01:01 PM
lets_fly's Avatar
i thought the mach motor was the 4v 4.6. the same as the cobra minus the blower?
Old 06-04-2007, 01:19 PM
the mach motor doesnt have forged rods and pistons but does have forge crank i believe. the cobra motor is also a iron block and the mach is aluminum. i think the heads and cams are the same. funny also is if you get an automatic mach they dont have forge cranks and redline at like 6k instead of 7k on on a standard mach
Old 06-04-2007, 01:36 PM
Cobra's oil pump has billet gears I believe and the Mach's doesn't. Heads are the same cams and all.
Old 06-04-2007, 02:30 PM
JMBLOWNWS6's Avatar
Ill have 90% of the parts for sale soon
Old 06-04-2007, 08:26 PM
blown4.6's Avatar
The best way to do it is to get the whole setup from a guy going to turbos. A local member sold everything off his car for 2200 which would allow you to bolt it onto a mach.
