clutch bolts! HELP ASAP!
im pullin the clutch as we speak. but how do i get the bolts off the pressure plate that connects to flywheel? the damn thing keeps turnin and i dont know how to secure it so it wont move so i can loosen the bolts. thanks!
you will need a flywheel turner tool. this will hold the flywheel as you loosen the bolts. and you will need it to tighten up the new setup. If you have a impact that bad boy will zip them right off without a flywheel turner tool.
