Anybody want to install my door speakers?
Old 06-12-2007, 07:19 PM
nickdotcom's Avatar
Default Anybody want to install my door speakers?
i was going to use the write-up below but i can't really understand it without some kind of pictures
anybody want to do it? or show me what to do? pm me with a price.
here is the tutorial, i got the same exact speakers he used
https://ls1tech.com/forums/wiring-stereo-electronics/126979-those-wanting-only-upgrade-speakers-camaro-s-come-here.html
EDIT: i'll be attempting this on friday since i have the entire day off. but will drive to someone else's place if there willing to help.
Old 06-12-2007, 07:32 PM
SILVER SS 00's Avatar
hey its very easy to put them on.if you bring it by will help you out
BBADWS6's Avatar
Do it yourself, its about the easiest thing in the world.
Old 06-12-2007, 07:54 PM
9 Second Club NA
Dragaholic's Avatar
True. Its really simple. If you're just replacing the speakers, you only have 2 wires, power and ground. I would suggest cutting the factory harness at the male side so that it stays intact with the female side in case you ever want to reinstall them. Then put whatever connectors you want at the end of the wires you cut. Its so simple.
Old 06-12-2007, 08:11 PM
nickdotcom's Avatar
that write-up makes it seem way more complicated than that
Old 06-12-2007, 08:39 PM
9 Second Club NA
Dragaholic's Avatar
Most the time I don't even read write-ups because its overloaded with too much info and it just clutters my brain. I like simple instructions. Thorough but to the point is the key.
Old 06-12-2007, 09:04 PM
Humanoid's Avatar
I did it drunk off my **** and it wasnt bad. You can do it man.
Old 06-12-2007, 10:27 PM
LS1LUNATIC's Avatar
Are you using the factory radio or aftermarket? If your using a factory radio, buy an aftermarket. If you have an aftermarket, run new wires and follow the instructions provided by the radio manufacturer. Just make sure to pick up the right harness for your radio, Bestbuy, Circuit city or Tweeter (lol if you can find one in Houston) can get you the right harness. Like some of the members said, its easy as hell. Dont do what dragaholic did unless you like jerry riggin your ****.
Old 06-12-2007, 10:38 PM
nickdotcom's Avatar
im using factory radio and i can't stand aftermarket
i would only get aftermarket if it had a screen
Old 06-12-2007, 11:00 PM
Shackleford's Avatar
I'm glad I put an aftermarket CD player in mine. The factory ones keep crapping out one me!
Old 06-12-2007, 11:04 PM
nickdotcom's Avatar
i just don't like how they look, they don't really have a benefit to me unless its got a screen
Old 06-12-2007, 11:23 PM
9 Second Club NA
Dragaholic's Avatar
My suggestion was not jerry riggin' by any means. He stated that he wanted to replace the factory speakers with aftermarket. I suggested to him that if he ever wants to reinstall the factory speakers for whatever reason, to cut wires on the male side of the connector. Aftermarket speakers aren't going to have the matching female plug. They will more than likely have spade connectors on the speakers.
So if he ever does reinstall the factory speakers, the factory male connector will need to be reconnected to the factory wire. If he's sweating over replacing the door speakers, I highly doubt he's wanting to go the whole 9 yards by doing a head unit, installing all new wire, etc.
I'm sure the factory wire (16-14 awg.) would be plenty anyway. He never mentioned anything about installing an aftermarket amp, which would lead me to believe that the speakers he'll be using aren't anything that will be pulling a ton of power anyway.
Old 06-12-2007, 11:33 PM
nickdotcom's Avatar
i already have an aftermarket amp and 12" sub, all im replacing is the door speakers because they are blown and i want something better than stock.
im just going to try and go by that tutorial since i know it was written for use with the stock HU and with the exact speakers i bought
they are alpine SPS-170a
Old 06-12-2007, 11:59 PM
9 Second Club NA
Dragaholic's Avatar
Is it a mono amp? Meaning meant for subs? To do it right, yes, I would suggest running new wire if you were amping the door speakers. 14-16 awg. should suit it well. If they're not going to be amplified, then just use the factory wire.
There's really no need for a tutorial. Take the door panel off, remove the plastic lining, remove the speaker (it snaps in), unplug it, cut the male connector, use the proper connectors on the factory wire to connect to the new speaker. Simple. If you want to run new wire, that is your choice.
Old 06-14-2007, 11:39 PM
nickdotcom's Avatar
you know i'm talking about the monsoon system right?
i've been reading that tutorial and it makes no sense, last chance for anyone to offer some help. im doin it tomrow
