Parting Red 95 383 M6 Firehawk
For all concerned... Some parts can ship out/ be picked up July 26!!
Here is a gist of the parts, I am just trying to see what interest there is out there. CAR IS A RED 95 FIREHAWK!!
All aftermarket parts have between 2-10k miles unless otherwise stated.
I dont have many pics right now, but they are comming, so be patient
These are the pics I have https://webspace.utexas.edu/srl264/firehawk/
https://webspace.utexas.edu/srl264/Hawk2
Prices dont include shipping.
Please send requests to srl264@mail.utexas.edu as my PM inbox is getting full, Thanks.
383 Shortblock (budget build, KB pistons, scat 9000 crank, scat I beams... perfect for NA) - 2000 obo
LE2 Heads - 1000
ARP Head Bolts (torqued once) - make offer
Delteq w/ opti - 400 SALE PENDING
Fidanza Flywheel (neutral balanced, 5k miles) - 300
Ram Powergrip HD Clutch (5k miles, not slipping) - 400
Stock T-56 w/ pedals, Hurst, Lou's Short Shifter, and Leather **** (49k miles) - 1100 (Clutch + FW not included )
Full T56 conversion (w/ Fidanza and Powergrip HD) - 1700 OBO
Alum Driveshaft - make offer
Meziere Electric WP - 125
160* Thermo - 10
SFI pulley w/ keyed hub and belt (not sure of brand) - 100
1LE Swaybars - make offer
Tunercat (cable is MIA) - 50
Original Firehawk Hood with intake box + K&N (needs to be painted or touched up, can prep or paint for more) - 750
3/8 1.6 NSA Pro Mags w/ guideplates- 150
52mm Bored TB w/ airfoil - 75
7.2" Trick Flow Pushrods - 50
236/242 .520/.540 112 Comp XE Cam - 125
Pacesetter Coated race LTs + Y-pipe - 300
Walbro 255lph Fuel Pump - 100
Adjustable FPR (not sure brand) - 50
Ford SVO 30lb Injectors - 200
Mufflex 4" Exhaust w/ hidden tip (custom w/ dynomax muffler) - 300
Stock 10 bolt w/ Factory 3.42s and Girdle + stud kit - 300
LG non adjustable LCAs (red) - 100
LG non adjustable PHR (red) - 75
OEM Bilstiens + Springs - make offer
Full Grey Leather Interior (decent shape, Id rate it a 7) - make offer
Radiator - make offer
Full Accessories - make offer
Wiring Harness + PCM (a couple splices, but nothing bad) - make offer
Stock 17x9.5 Painted Hawk Rims (can also polish) - 800
ABS delete with linelock - make offer
Any front or side body panels - make offer
Doors - make offer
Brakes (rotors arent in the best shape) - make offer
Im just listing everything I can think of... if you need it, just ask. The car was hit in the rear, so anything from the doors forward is fine and I havent inspected everything like the rear end or exhaust yet. If anyone wants to buy the car outright, just ask and we can work something out.
I would prefer NOT to ship the larger items...
The car is located in Austin, TX.
LE2 Heads - 1000
160* Thermo - 10
Doors - make offer
The delteq is probably already spoken for... but I will make note if they fall through.
Just so you know, the opti is damaged, but the signal is good. The coil input piece broke off.
I think they are all the same. The signal gets tapped into on the passenger side of the intake manifold where there is a flat 4 wire connector.
I will get pics as soon as I can.
