P0101: MAF sucks at life
Howdy! Definitely just got this code today when I was playing around comin back from my buddies house. I was going WOT in Third when the SES light popped on so I stopped by Oreilly's on the way home and apparently I got this code. I was almost certain it was going to be my cats gone bad again but apparently not.
Ok...what is there that I can do to fix this problem? Since its a Range/Performance problem, I am assuming it may not be the MAF itself and maybe one of the other sensors.
Does anyone have an LS1 MAF sitting around or maybe an LS6 if it is compatible jsut to check and see and maybe ill buy from you? thanks -Karl
Get a SLP MAF. My maf went bad the day after i bought my car. A few mods later I finally fixed it with an slp one. I picked up .5 seconds. Its just an LS6 MAF that they modified.
I had the same thing happen to me once. Do what Firehawk #07 said. That was my problem and it was from a little to much oil on the K&N. If that doesn't work I may have another MAF laying around the house.
i just cleaned it not too long ago but i may try that again tomorrow. so the LS6 maf shouldn't cause any issues?...i wouldn't think it would but just thought id double check. i may hit you up on that 01ss. appreciate it.
8 Sec Tuner
P101 is Maf Performance code most likely the maf still works. Check the engine sensors fuse under the hood. Have you been tuned? What mods do you have on your car?
im stock minus lid and loudmouth.....never been tuned. wouldn't i be noticing other issues if it was a fuse? the light went off again today so is definitely intermittent
