How many 02 sensors do our cars need?
I went to autozone and the guy told me he THOUGHT the car needed three, one up by the manifold, and two after the cats.
O'Reilly's said i only needed one
I will aBoligize now for my ignorance
wait so i can run with out 02 sensors?
i dont have cats, so i will need 4, are all four the same? can someone post or pm me part numbers or links to what sensors i need.
what are sims?
what are sims?
you can run without the back 2
you absolutely must have the front o2 sensors
sims are simulators, they plug into the rear O2 spots and tell the computer that the cats are working fine so you don't through a SES light. you can also get them tuned out
Sims are simply a device with an 02 sensor plug in it that sends a steady voltage signal to the pcm in a range that keeps the check engine light from triggering. These can only be used on the rear O2 sensors aft of the converters on each side, their inputs only check against those of the fronts, if a noticeable variance between the two is found by the pcm, the ses light is triggered. The fronts control air fuel ratio and are not to be removed or altered. Removing your cats almost always triggers the ses light, and that is why sims are commonly used when the cats are removed.
As for your problem, I would first start by listing the specific codes you are getting by scanning your car. You probably need to deal with your rear O2's throwing codes rather than buy sensors.
ok thats cool. So what do yall recommend for the two 02s?
The sims can be bought online too? any sites yall recommend?
I will have to go to a mechanic to check the codes, a while ago a shop checked them, and he removed the code, but then it came back on in a few days, then it went away, then it came back on. I will go buy firestone have them check it out
THANKS!
THANKS!
Originally Posted by osvaldo
SO how would i get them tuned out?
Call GForce, Mikey can take care of you.
Tell him that you want 7 O2 sensors installed. That way your covered forever! JK
Do you know how much?
Thanks
Thanks
Yea, I know how much bro, 281-993-5451.
You can also find out how much by going to their website and asking them.
They are all real nice guys up there so dont be afraid to ask questions.
If you want if fixed right, just let them drop a stroker in it for you, that will solve all your problems in life.
