Motor Mounts
Old 12-22-2007, 12:15 PM
zwhb02's Avatar
Default Motor Mounts
I Have A Question On Motor Mounts. When Searching For New Motor Mounts For My 99 Camaro I Find That When Buying The Poly Mounts You Only Get The Inserts ??? Not The Whole Shell ?? What Does This Mean ? And Can You Buy The Whole Motor Mount Or Would I Be Better Off Buying Oem Motor Mounts?
Thanks In Advance.
Old 12-22-2007, 12:34 PM
deadlyz28's Avatar
get the inserts, you have to drill out the holes to seperate the shell, pop in new one and attach with bolts. i gotta do this. lot of work for nothin.
Old 12-22-2007, 12:57 PM
BigSteele's Avatar
Yes You Re Use The Stock Shells With New Inserts. The Big Part Of The Job Is Removing/Installing Them, Not Swapping Them Out, Dont Worry
Old 12-22-2007, 01:01 PM
sroach20's Avatar
you just need a drill, a blow torch, and about 30 minutes.
Old 12-22-2007, 02:28 PM
That's what she said...
TheBlurLS1's Avatar
This information is correct. I used a die grinder on the factory rivets (holding the clam shells together), then popped them apart with a screw driver.
Poly mounts really do make a difference. My motor barely moves and it cams pretty ridiculous. If you haven't done the headers, and plan on it, I'd wait 'till then to do the mounts. They are a bitch to remove with the exhaust still in place.
Old 12-22-2007, 02:37 PM
I8ASaleen's Avatar
motor mounts are teh suck to drill out.
Old 12-22-2007, 02:48 PM
deadlyz28's Avatar
tackling this project when i get home from vacation
Old 12-22-2007, 02:53 PM
I8ASaleen's Avatar
The biggest PITA was getting all the bolt holes line back up once the new mounts were back in the shell and on the motor. One thought, get a bolt threaded and then line up everything...
Old 12-22-2007, 05:55 PM
10SecDreamer's Avatar
a vise helps alot also, by holding the clam shell to drill it and by pressing it back together
Old 12-22-2007, 08:14 PM
I8ASaleen's Avatar
Oh yea, I had to use a vice, there was no way in hell I woulda been able to drill through those mounts w/o it.
