FS: NOS Progressive Contoller 15834
I paid 560.00 for this controller NEW and I have used it 4 times. I have controller and instructions but NOT the original box. You can contact GREG at 817-937-1283. $400.00 Firm
THX Here is decsription below:
Programmable Progressive Nitrous Controller This topoftheline unit can be programmed to control both the amount of Nitrous that is flowed to the engine (from 0100%) and the time desired to ramp up from first hit to full flow. For example, you can program the controller to flow 25% of the Nitrous 1.5 seconds into the run and increase it to 75% Nitrous at 5.3 seconds. Or, it can go all the way to 100% much sooner. This enables a racer to fine tune the power curve of an engine to best utilize prevailing conditions. It can also be used to activate a retard box or 2nd stage of nitrous.
Installation Notes
Kit #0050NOS Required. All NOS controllers are safe to use with all production NOS solenoids. Other manufacturer's may have excessive draw. Nitrous solenoids should not exceed 10 amps. Fuel soleniods should not exceed 5 amps.
Features
Control Nitrous Amt. To Engine
Control Ramp Up Time Desired
Fine Tune Power Curve
Sophisticated and Progressive
Very Easy To Use
Installation Notes
Features
Very Easy To Use
Installation Notes
Features
Very Easy To Use
Installation Notes
Features
Very Easy To Use
Thats a nice piece and a good price. You are probably gonna get a few "Nitrous Guru's" on here that are going to say that theres no need for a progressive controller. Those are the ones that always blame either the track or they have too many passes on their tires when they have problems at the 60ft.
YEP I agree but what I like BEST about it is that you can run a % of total shot so that you can pill for say 300HP and if the track won't hold that you can specify 50% of total shot or 150HP. This works really well for street and strip applications because of course you can't run as big a shot on street tires as you can on slicks
