Tune needed in Houston area.
Here's the problem...
2002 TA bone stock 50k miles with a 2800-3200 Lock up Converter. I have drove the car 100 miles a day for the last two weeks.
Car is stalling at low rpms mainly when turning, or at low speeds with the a/c on when stopping. The car idles in gear at 600 rpms. When it starts acting up the tach bounces beween 400 and 600 rpms.
The car would not idle at all after installing the converter. I had to hold the throttle to keep it running, after about 2 minutes it seemed to be ok.
The new converter was much lighter then the stock converter. Could this be causing the problem?
Will this require a tune?
Is there a simple way to idle up the engine permanently?
Where is a good shop and how much will this cost?
Needing a Tune and Transmissions Help
If you are on the North Side of Town stop by and see us at Fatal Performance. We can tune with either EFI LIVE or HP Tuners what ever your choice.
We are running a special for life time tune for the month of March of $ 375.00 but you need a coupon. Just ask for one when you get there. Located at 4829 FM1960 RD West. About 5 miles east of I-45 on FM 1960.
Good Luck and if we can help give us a try!
